Sponsored by: Real Truck
WANTED: Wiring diagram for '01 F250 4X4 crew / diesel
Old Dec 21, 2004 | 09:06 AM
pcerra's Avatar
pcerra
Does anyone have a wiring diagram for an '01 F250 4X4 crew diesel that they can share?
Thanks
Pat
Old Dec 21, 2004 | 10:55 AM
FortyFords's Avatar
FortyFords
What area in particular do you need ,its a big book ?
Rich
on edit you could join www.alldata.com for $14 and have the wiring harness at your disposal for a year and also print it off when needed
Old Dec 21, 2004 | 02:41 PM
pcerra's Avatar
pcerra
Hi thanks for the reply. I am looking for the wire coloring out of the fuse block so that I can use a ign switched customer access wire for 12V.
Thanks
Pat
Old Dec 21, 2004 | 07:51 PM
FortyFords's Avatar
FortyFords
On 01 superduty's there is a 12v switched customer access wire (Light Blue with a pink tracer) LB/pk this was setup for the 12v source wire for the PTO
Chk your owners manual for that fuse
That wire is dead ended up under the dash,it should be tied back with a few others.remove the fuse access panel look over to your right and follow the harness up towards the radio.
In 02 they changed the colors of this wire to wh/lb .
Rich
Old Dec 23, 2004 | 07:54 AM
pcerra's Avatar
pcerra
Rich,
Thanks for the reply. The information was exactly what I was looking for. I found the wire and the fuse and hooked it up. Worked great.
Thanks again and Happy Holidays
Pat
