1939 Ford 3/4 Ton Upgrade
Old Dec 15, 2004 | 10:19 PM
bruce91852's Avatar
bruce91852
Hello to the Group,
I have 2 1939 Ford 3/4 Ton trucks that I am upgrading to look original but want drive down the highway with a nice feel.
As Newbie, I would like to upgrade the suspension and add disc brakes to the front end. I do not need to go as far as a IFS but would like to add shocks. Also, I would like to upgrade the rear end so I would be able to do more than 55mph.
I have learned is that the 3/4 ton may not work with these kits out there for the 1/2 ton. Chasis Engineering did not know about the 3/4 ton since they do 1/2 tons.
Any thoughts from the experts?
Bruce from Dallas
Old Dec 16, 2004 | 05:22 AM
41inWV's Avatar
41inWV
I put disc brakes on the front of my pickup, I used ECI (here's a link to their site):
http://www.ecihotrodbrakes.com/
There are several good brake conversion kit companies out there, but at the time I was looking, ECI was the only one I found that could handle the 5 X 5 1/2 bolt pattern of my '41.
http://www.ecihotrodbrakes.com/early...nversions.html
As for redoing your trucks rear end......not sure exactly what you have in mind....are you keeping your flathead ? are you wanting to go to an open drive shaft ? etc.
Pete and Jakes http://www.peteandjakes.com/ is another good resource as far as looking at the front end suspension since your apparently wanting to keep your front solid axle.
Hope this helps
Old Dec 16, 2004 | 06:01 PM
41Clay's Avatar
41Clay
Welcome to FTE Bruce! I sure hope that we can help you out here.
Hmmm. So how are the leaf springs set up on the front of the 3/4 '39s? Are there 2 going the legnth of the frame or 1 set accross with the axel?
Is your rear end already and open drive unit?
Good luck!
Clayton
Old Dec 17, 2004 | 07:13 PM
bruce91852's Avatar
bruce91852
41 Clay and 41 in WV,
41 in WV do you have a 3/4 ton truck?
I will look into the ECI for the brake conversion kit. The flathead I have is a newly rebuilt when I bought the truck, but it is 1952 engine in a 1939 Truck which is fine with me. A flathead is still a flathead.
I don't mind using a open shaft.
The front leaf springs are across the front axle and the original rear end with a closed shaft.
Thanks
Bruce
Old Dec 22, 2004 | 02:35 PM
alittle40's Avatar
alittle40
Bruce,
Give my user name a click and then click on my gallery pictures. Take a look at the rear end set up that I used on my '40 and see if that's what you had in mind. That's a nine inch rear with parallel leaf springs.
