new 1406 on 360 idle rough
Old Sep 21, 2004 | 05:51 PM
Bookman's Avatar
Bookman
Unhappy new 1406 on 360 idle rough
Help!!!!! I by accident adjusted the air screws out and then in on the carb thinking it was the idle screw and now it rons really rough on idle and at the stop light like a heavy cam. Before I make it worse get me going in the right direction.
Old Sep 21, 2004 | 07:50 PM
Gary B's Avatar
Gary B
back one or both idle air screws off a little bit and see if it smooths out.then screw them in one at a time till the engine slows down and back it off until it smoths out.do the same for the other one,may be necessary to go back and forth to get the best idle quality. good luck
Old Sep 21, 2004 | 08:16 PM
F150'89's Avatar
F150'89
Old rule of thumb is to turn the screws in until they stop and then back them out 1&1/2 turns. Fine tune until engines run good. Do not over tighten the screws only turn them in until they stop.
Old Sep 22, 2004 | 03:58 PM
Bookman's Avatar
Bookman
I have adjusted air screws on 2 stroke dirt bikes and that is 1 1/2 - 2 1/2 turns out but it looked like these were out more than that initially. Thank for the start i'll go from there.
