1990 F250 rear end
Old Sep 18, 2004 | 08:55 PM
shiney's Avatar
shiney
Question 1990 F250 rear end
how can I tell if there is a 4:10 rear end in this truck? (door code?)
thanks, shiney
Old Sep 18, 2004 | 09:07 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to FTE! I will be moving this to the Transmission, Differential, Axle and Transfer case forum where someone can give you explicit instructions on how to get the answer you need.
Thanks for using FTE as your source of information. Please check out ALL of our forums. FTE is huge and has a lot to offer and many forums to find or give info in. Also check out the forum guidelines and the READ FIRST notes. They'll help you along the way.
Old Sep 19, 2004 | 12:17 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Yep, the door code will have the info. Code 35 is 4.10's if I remember correctly. Code 39 is 3.55. If your code is alpha-numeric as opposed to 2-digit, the alpha character indicates a limited slip differential. Check out the 'tech articles' section of this website, under 'decoders' for more info on axle codes, etc. You can also look on the ID tag attatched to one of the axle's diff cover bolts. The ratio will be stamped on it as well as the ring gear diameter and manufacturing code. An 'L' in between the first and 2nd digits of the ratio indicates a limited slip differential. The first digit may be hidden under the bolt.
granny_rocket
17
Aug 21, 2016 08:22 AM
ktgovols
May 17, 2015 09:35 AM
sbrider
2009 - 2014 F150
Feb 8, 2013 01:48 AM
meborder
Aug 15, 2011 06:24 AM
Riderman
126
Feb 7, 2011 02:29 AM
