SVO Heads
Old Aug 14, 2004 | 01:49 AM
Librac23's Avatar
Librac23
Question SVO Heads
Greetings,
I own a 90 Ranger 2.9L 4x4 and I am looking for a set of SVO Heads for my V6.
I dont know where to look for the very elusive heads...I am also looking for a header kit for the same engine...any suggestions would be and will be greatly appreciated.
P.S. aprox on cost of above mentioned items.
Thank You Librac23
Old Aug 14, 2004 | 05:59 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Never heard of SVO heads for the 2.9L.
JBA makes headers.
Old Aug 15, 2004 | 12:34 AM
Librac23's Avatar
Librac23
thanks for the info.
I'm looking for heads really that are compatible with the 2.9L other wise I will have to find an engine that already has them.
Old Aug 15, 2004 | 12:48 AM
TigerDan's Avatar
TigerDan
There are of course the World Products heads, but they are not a performance improvement, just redesigned to solve the 2.9 cracking problem. I have them on mine. -TD
Old Aug 15, 2004 | 12:55 AM
Librac23's Avatar
Librac23
how much did you pay for them? and where could I get them in Minnesota?
Old Aug 15, 2004 | 12:59 AM
TigerDan's Avatar
TigerDan
They are available mail-order from several of the large catalog companies, hold on and I'll find the link. -TD
OK, here's one from Summit:
http://store.summitracing.com/default.asp?target=edepartment.asp&N=120+429492523 2&x=12&y=7
Old Aug 15, 2004 | 01:23 AM
Librac23's Avatar
Librac23
thanks much
Old Aug 15, 2004 | 01:33 AM
TigerDan's Avatar
TigerDan
No problem, and welcome to FTE! Lots of knowledgable people here, and some durn good moderators. Ken00 helped me out a bunch when I first came on here. -TD
Old Aug 15, 2004 | 01:39 AM
Librac23's Avatar
Librac23
cool....aside from the heads..is there any way to really trick out a 2.9L? I might have to find a 4.0 and Pump it...or there is another way I think I could go..
quick question. will a 289 Fit in a 90s ranger chassis with out too much modification?
Old Aug 15, 2004 | 01:51 AM
TigerDan's Avatar
TigerDan
Yes, it's a very common swap, there are motor mounts and headers available from many different sources. Planning a 5.0 swap onto mine, looking for an engine right now. Here's some more links with some info:
http://www.mercuranger.com/
http://www.v8-ranger.com/index.shtml
http://www.jamesduff.com/broncoII/v8conversion.html
As far as tricking out the 2.9 goes, there isn't a whole lot of bolt-on stuff available, you would have to tear into it and do some basic hi-po machining mods, and for the money you might as well swap in a 4.0 or V8. -TD
Old Aug 15, 2004 | 02:39 AM
Librac23's Avatar
Librac23
Thank you again TD...this info will help greatly. you have given me other options to explore...
The 289 that I have came out of a 67 For Galaxy..would have been nice to rebult that car but it sat on the ground for too many yrs and the frame.....well was considerably rotted...so my Dad and I pulled the motor and the Trans....impressively the tail seal is in perfect condition..the yoke from the Driveshaft came out still Shiny and the fluid is and still...Bright red...although the engine oil looked like Choclate syrup...
The Motor was carb fed...and I would like to retain the Fuel Injection...I know I will need to replace the stock computer..but they dont make a puter for a 289...so would the puter for a 302 work in its place? and I was planing on using a Painless wiring harness...so all of my own Old stock harness will have to go right?
well...thanks again..you have helped me out greatly
Librac23 90 Ford Ranger EXT cab
Old Aug 15, 2004 | 03:39 AM
Mike W's Avatar
Mike W
A 302 is a 289 with a slightly longer stroke.
Old Aug 15, 2004 | 11:33 AM
TigerDan's Avatar
TigerDan
As Mike said. So the 302(5.0) EFI stuff will bolt right on to the 289. And you shouldn't have to replace the entire harness, just the engine section. -TD
