painting calipers
Old Aug 12, 2004 | 09:28 PM
InboundFX4's Avatar
InboundFX4
Arrow painting calipers
I have seen some paint kits for coloring the calipers. I like the idea for an inexpensive upgrade. Has anybody done this done this to their truck? Does the color last? Looking for pictures too.
Old Aug 12, 2004 | 09:50 PM
khendrix's Avatar
khendrix
I painted the calps and drums on my friends Focus. Painted them yellow like the car and the color has remained bright ever since.
Old Aug 12, 2004 | 11:49 PM
TWellmann's Avatar
TWellmann
I painted mine. Picked up a can of racing red caliper paint from AutoZone for around $8.
I've got a couple pics in my gallery...they don't show the calipers all that well, but you'll get the idea. For some reason the red looks orangeish in the pictures - it's not. The color matches the red in the Fx4 logo so I think it ties in to the paint scheme of the truck pretty well...
It was easy to do. I just jacked my truck up and removed one wheel at a time. I covered the entire side of my truck and wheel well with a plastic drop cloth so airborne paint wouldn't hit my truck. Then I took a couple of old TShirts and covered the rotors and axel area and packed the areas in between the caliper with fragments of a paper towel and used tape to mask off areas I didn't want to paint. Once that was done I simply sprayed them with 3 or 4 coats.
I had trouble getting the paint to stick in a few areas on the caliper because it didn't want to bond to the metal that well...I solved this problem as it dried by just taking a brush and spread it around a bit on the areas that weren't sticking well then continuted with the additional coats.
I did this about 3 months and 7000 miles ago and haven't had any troubles with flaking or chipping.
Each wheel took about 20 - 30 minutes.
Old Aug 13, 2004 | 05:34 AM
asinatra's Avatar
asinatra
If you look close enough you can see what i did, i painted the whole rotor and calipers. It was pretty rusty before, so it helps if you look at yours then look what i have done ...With krylon high temp paint, "caliper" paint is just a name, go with high temp 500+ or something.
Old Aug 13, 2004 | 04:56 PM
Medicine Man's Avatar
Medicine Man
Talking
I must admit...painting the calipers was the first "modification" that I made to my 04 Supercrew Lariat 4X4. I went with a red plastic-coat paint (brush-on) which worked perfectly. I removed each wheel and carefully painted the calipers. I have nearly 2000 miles now and the paint has held up well. I get many comments and stares regarding the look. My rig is oxford white and the red calipers really add to the race truck look. Additionally, this personalizes my truck. I don't recommend that you do this...I want my truck to be different..ha ha ha...
Old Aug 13, 2004 | 07:14 PM
InboundFX4's Avatar
InboundFX4
Does applying paint to rotors affect their wear/efficiency? Seems like the paint would rub off too.
Old Aug 13, 2004 | 09:14 PM
txfx4x4's Avatar
txfx4x4
Painting the rotors and calipers is not something you would do if you were concerned about the efficiency of the the braking system. Paint holds in heat. Since I use my rig for towing, I wouldn't even consider painting the calipers. I'm more concerned with function over appearance.
