Passenger Air Bag Off (Annoying Dash Light)
Old Aug 11, 2004 | 05:30 PM
edcastle's Avatar
edcastle
Angry Passenger Air Bag Off (Annoying Dash Light)
2004 F-150
Has anyone experienced the annoying BRIGHT LIGHT of the "PASSENGER AIR BAG OFF" in the upper center of the dash? A small lunchmate cooler and a light Briefcase in the passenger seat make this light come on, and at night it is very distracting! Can this light be deactivated? Sensing the weight of a child in that seat that is less than 60 pounds also makes this light come on.
I'm all for the 2nd generation air bag, but this light really bugs me! I wish I could turn this light off without affecting the air bag sensing ability.
Any answers?
Old Aug 11, 2004 | 05:49 PM
76fordf100's Avatar
76fordf100
It's just a light, pull the panel out and remove the bulb...
shane
Old Aug 11, 2004 | 06:32 PM
1956MarkII's Avatar
1956MarkII
...or buckle the seat belt....
Old Aug 11, 2004 | 07:07 PM
Racerguy's Avatar
Racerguy
If you remove the bulb you will probably find the air bag light on the instrument cluster blinking at you because it thinks there is a problem.
Old Aug 11, 2004 | 07:27 PM
gmcplus03's Avatar
gmcplus03
just something i've gotten used to, its designed to be that way. easier than having to remember to turn the airbag on or off manually.
Old Aug 12, 2004 | 12:08 AM
Toreador's Avatar
Toreador
Black tape would work.
Old Aug 12, 2004 | 01:17 AM
kize's Avatar
kize
Better yet, buckle your lunchmate in!
Old Aug 12, 2004 | 06:19 AM
bcjim's Avatar
bcjim
Im not certain, but the seatbelt probably has nothing to do with it, its just the weight in the seat or lack of weight..Racerguy and Toreador are both correct on this one I would say..
Old Aug 12, 2004 | 07:58 AM
ieee_raider's Avatar
ieee_raider
Mine does it with my dog in the seat...
I would just try unplugging it.
Just pull your dash panel off, there's a little plug back there at the top. Just unplug and I bet all works fine.
If it creates another annoying light, then plug it back in and try black tape.
Old Aug 12, 2004 | 11:20 AM
vader716's Avatar
vader716
Couldnt you just put the stuff on the floor?
Old Aug 12, 2004 | 12:35 PM
chopperdude's Avatar
chopperdude
I hate all things about a vehicle that tries to be too smart.
Seat belt warning, air bag light, auto locking of doors, and so on.
Old Aug 12, 2004 | 01:01 PM
InboundFX4's Avatar
InboundFX4
I was skimming through the manual a few days ago and saw a section on turning off the auto locking doors.... I beleive you can turn the seat belt warning off too. Not sure abuot the air bag though.
Old Aug 12, 2004 | 02:17 PM
chopperdude
I'll check it out...I've heard some have trouble getting the seat belt warning set to OFF...thanks! It's a PITA when you're doin utility type stuff like pull up and get out, etc to have the doors lock...good if ya have kids I guess.
Old Aug 13, 2004 | 02:36 AM
timhood's Avatar
timhood
I followed the manual and was able to disable a lot of that stuff...seat belt warning, door locks, etc. Only one of the procedures did I have to try more than once to get it set the way I wanted. There's no way to disable the airbag light on the dash, though.
I had a big screen TV with an annoyingly bright power light. Black electrical tape took care of the issue. I think with a little time, a piece of tape could be cut to match nicely to cover the light without making it look tacky.
