1997 F-150/No Lights
Old Jul 20, 2004 | 03:07 PM
ryan_37's Avatar
ryan_37
I have a 97 F-150 4wd. Currently I have no parking lights, tail lights, and instrument illumination. All fuses checked out ok. However, there is no power to the fuse labeled "parking & tail lamps" in the power distribution box. What do I look for next?
Old Jul 20, 2004 | 08:21 PM
Dealford's Avatar
Dealford
Your F-150 may be the same as a Ranger? The Ranger has a 20a park light fuse in the dist.box AND a 15a in the fuse panel inside the cab.
AL.
Welcome to FTE!
Old Jul 20, 2004 | 09:06 PM
HomerWinzlow's Avatar
HomerWinzlow
If there is no power to either side of the fuse then the 175 amp maxi fuse would have to be blown or a burned up PDB, which is unlikely. All the fuses from that maxi fuse would have no power. Pull the fuse out and test the connectors themselves, you may just have a loose fitting fuse in the PDB or a poorly grounded test light/multimeter.. Also you have a park lamp relay which may be bad.
