idle problems
Old Nov 3, 2002 | 08:27 PM
marrug's Avatar
marrug
idle problems
Old Nov 4, 2002 | 06:55 AM
mayerst's Avatar
mayerst
idle problems
I have a 1998 explorer w/v6 sohc automatic. When the engine is cold it has an eratic idle until it warms up. I have changed the IAC cleaned the throttle body and checked for vacuum leaks. It has no stored odbII codes. I have run out of things to check for, any suggestions?
Old Nov 4, 2002 | 09:22 AM
SplashMan's Avatar
SplashMan
idle problems
Did you reset the ECU after you did the IAC and MAF? Have you tried running a bottle of STP fuel injector cleaner through it? Could also be a sign of one or more of your 02 sensors going out.
