Transmission/Transfer Case: Death Scream or Good To Go?
Old Nov 5, 2002 | 07:23 PM
bandlow's Avatar
bandlow
'95 Explorer XLT, 4.0L, AT, 4R55E, 4WD BW 44-05,118,000 trouble free miles. Excellent maintenance (do it myself); last transmission flush at 90,000.
At aproximately mile 1000 of an 1100 mile trip to visit mom in Florida. At 70mph steady cruise, the 4WD and 4WD LOW lights both came on steady. Hmmmm... not good. Checked switch firmly in 2WD, no abnormal sounds or change in power. Just as I was beginning to pull over, the lights went out. Since I was close and it was working, I kept going until a convenience store that was within walking distance. (When your mom is 81, a six pack helps.) I couldn't resist engaging the 4WD in the parking lot to check engagement and the lights. Everything seemed normal. After returning to 2WD, I put it in reverse. Reverse didn't engage and the sound could only be described as metal in pain. (Somewhere between a screech and a howl with no engagement or movement. Uh-Oh. I couldn't pinpoint the location - had to stop the pain. Good possibility that is was the transfer case area.)
I went back to neutral and let it roll back out of the parking space. Engaged DRIVE and went the last mile with no problem.
This morning I checked all fluid levels - including the transfer case - and all were normal. Everything looked good underneath and under the hood. I drove it three times today and it worked fine. Tomorrow I'll disconnect the battery to reset the computers.
My plan is to drive it locally the next three days and if it works, chance the 1100 miles back to Texas on Saturday. If it acts up here, I'll rent a U-Haul trailer and take it home for some TLC. (Opera House: I'm watching your progress. You're my hero. I want to do a rebuild too. I just wanted it to die closer to home.) That's also the plan if it dumps on the road. Unfortunately, all my diagnostic equipment and most tools are in Texas - after all it was an incredibly reliable vehicle.
Questions for any takers:
Should I electrically disable the the shift motor and/or the speed sensors in case it is attempting to engage 4WD Low with the switch in 2WD or will this just confuse the PCM/GEM computers? (I just want to get it home and make it right later.)
Has anyone had this before? (Thread search didn't come up with anything.)
What would you do? (Sorry, no points for "take it to the Ford dealer".)
Anyone want to set up a pool on how far I make it? I'll supply progress reports from my overnight stop or the "Bates Motel" nearest my breakdown site.
Thanks in advance,
Rich
Old Nov 9, 2002 | 08:34 AM
marrug's Avatar
marrug
Sorry dont know squat about transfer cases, but anybody with your sense of humor needs encouragement. Besides dont you just hate it when you write a nice long post and NOBODY answers?? As I write this its Sat AM, and dying of curiosity...write when (if) you get home....how did you do??
Old Nov 10, 2002 | 05:46 AM
bandlow's Avatar
bandlow
marrug,
Thanks for the reply. Sometimes a post is too long and in this case there may be nothing to say but "good luck!"
I don't know much about transfer cases either but I'm learning fast. My concern when the 4WD lights came on at 70mph cruise was that a shift signal was being sent which could really do some damage. The metal to metal grinding and no shift seemed to verify that.
I have learned that you can remove the shift motor and manually check or position the selector shaft into the 2WD mode. I haven't done that yet since its now working OK. If the lights even flicker my plan is to stop and disconnect the shift motor.
It's Sunday morning at the Highway Hotel in Baton Rouge. I made about 700 miles yesterday with no problems. Less than 500 to go. It's looking good.
Thanks again for the reply.
Rich
Old Nov 10, 2002 | 09:17 AM
CNTHOR's Avatar
CNTHOR
One thing you should know is that THERE IS NO CHANGE IN THE SHIFT MOTOR POSITION WHEN YOU SHIFT FROM 2WD to 4WD-AUTO. The only time the shift motor is supposed to change is when you shift into 4wd-low.
the three modes of the 4wd system on the '95 control trac are as follows
1. 2WD
borg warner 44-05 transfer case in high gear range
(this is the shift motor position)
transfer case clutch disengaged
front axle disengaged at the front differential
2. 4wd auto
transfer case clutch sent 6 volts (minimal engage power)
front axle engaged
the G.E.M. computer will send more voltage to the clutch if it believes the rear driveshaft is spinning faster than the front (rear wheels slipping)
3. 4wd-low
transfer case in low (the only time the shift motor is used)
transfer case clutch sent 12 volts (full power)
front axle engaged
when you 4wd-low and 4wd lights come on it means that the G.E.M is reporting an error with your 4wd system. But the lights are supposed to BLINK, not come on solid. I think a solid set of lights might be a short or a problem with the G.E.M computer. They are known to go bad (They use flash ram) When you got both light on solid It might have been a power problem with the GEM
Old Nov 10, 2002 | 09:22 AM
CNTHOR's Avatar
CNTHOR
the raer axle is always supposed to be engaged. so when you car didn't shift into reverse that sounds a little disturbing. Are you sure you have been changing the one quart of transmission fluid in the transfer case (it takes tha same mercon fluid as your transmission)
here is a copy of a reply I posted awhile back detailing the '95 control trac 4wd
Heres a reply I sent to someone else regarding the same topic. It basically tells you about all the 4wd componants on the '95
I'm Glad I could help.
I had a problem with my transfer case. the Ford dealer gave me a qoute on $1750 to replace the transfer case. I felt like the symptons didn't match the diagnosis so I was forced to learn how the 4wd system works on a 1995. the result was that I changed a $30 speed sensor and now my system works fine. (and I learned quite a bit about the 4wd control-trac system.
Here's the $5.00 tour of your 4wd system.
1. PCM
The Powertrain Control Module (PCM) is the main computer for your car and also controls the engine and Transmission. the PCM is mounted on the engine side of the firewall in front of the passenger air bag.It is not serviceable but is very easy to change ($300.00). It is notorious for going bad at about 100,000 Miles
2. transmission.
This transmission is all electronically controlled. It is controlled by the Powertrain Control Module (PCM). It is also known as a weak transmission looking for a reason to fail. I had mine fail on me and it cost $3,000 to rebuild
-GET a Small external tranny cooler and have it connected in series with the existing cooler so that the engine pumps the fluid through the original cooler first, then the auxilary cooler and then back to the transmission (PEP BOYS sell the cooler for $40.00 and will install it for you for a small fee)
-GET the fluid PUMPED OUT every 12,000 miles
-GET the fluid PUMPED OUT and have the filter changed every 24,000 miles.
3. GEM
The generic Control Module (GEM)is the second computer in your car (the third computer controls the ABS and is mounted somewhere near you battery). It is mounted in the dashboard behind the radio. It controls the Inside Lights, Windows, Wipers AND TRANSFER CASE (believe it or not) among other things. It is about $250 an is also very easy to change. And is aslo notorious for going bad
4. BORG-WARNER 44-05 transfer case
The transfer case is electronically controlled by the Generic Control Module (GEM). It has a INTERNAL clutch that is controlled by a solenoid (Electric Clutch). it also has 3 speed sensors mounted to it (one is the main vehicle speed sensor and is not used by the vehicle in controlling the 4wd system) two of the speed sensors are very important for 4wd operation. They are called HALL sensors and one measures front driveshaft speed the other measures rear driveshaft speed. The transfer case also has a ELECTRIC SHIFT MOTOR the is used to preform a mechanical shift of the transfer case from it's high gear range to it's low gear range.
In 2wd mode the GEM DISENGAGES the Clutch and the front axle (through the VACUUM SHIFT MOTOR).
In 4wd-AUTO the GEM engages the front axle and SLIGHTLY engages the electric clutch in the transfer case to send power to the front driveshaft (but still allow for slip so that your drivetrain isn't stressed if you are turning). It also starts reading the HALL sensors. If the rear driveshaft is spinning much faster than the front the GEM increases power to the electric clutch until the driveshafts are going close to the same speed. (NOTE THAT THERE IS NO MECHANICAL SHIFT IN THE TRANSFER CASE WHEN YOU GO FROM 2WD to 4WD-AUTO)
In 4wd-low the ELECTRIC SHIFT MOTOR shift the transfer case into low gear range (2.88:1) and fully engages the ELECTRIC CLUTCH.
This is what I learned about the transfer case:
-CHANGE THE FLUID EVERY 24,000 Miles (it only takes 1.5 quarts of mercon transmission fluid. Make sure you take the fill plugh off before you take the drain plug off in case you can't get the drain plug off you still have fluid in the transfer case)
-If you have a problem with the 4wd high mode it is probable one of the HALL sensors going bad (the rear one took me 5 minutes to change. The fron one requires removing the ELECTRIC SHIFT MOTOR to access)
-Keep the car in 2WD mode unless you need the 4wd don't waste your electric clutch on dry pavement.
-don't shift into 4wd-auto if you are going above 30mph. I have heard of people damaging the front axle if the axle doesn't engage properly
-once a month, on wet roads drive for about a mile in 4wd-auto to lubricate your front axle fully.
- TEST YOUR 4WD-LOW SOMEWHERE NEAR YOUR HOME THE FIRST TIME (You wouldn't want to find out that the shift motor got stuck in low gear in the middle of the desert would you?)
5. REAR AXLE
Most of the rear axles in '95 were the limited slip type. They take 80w90 hypoid gear oil and require 2oz of a special ford additive for the limited slip axles.
CHANGE YOUR AXLE OIL EVERY 50,000 miles
CHECK THE CONDITION OF THE OIL EVERY YEAR
MAKE SURE THE BREATHER TUBE ON THE AXLE DOESN'T GET BRITTLE AND BREAK
6. FRONT AXLE-DANA 35IFS
they are not limites slip (if you get stuck only one front wheel will spin)
the axle is supposed to tak a synthetic gear oil, But even the dealers use the same oil as the back.
the control module you found the tubes disconnected from is called the ELECTRONIC VACUUM CONTROL VALVE. The reason two line are going to your vacuum shift motor on the axle is to because the axle has to be DRIVEN ENGAGED and DRIVEN DISENGAGED. If the designers had only one line to DRIVE IT ENGAGED the they wouldn't have any way to disengage the axle once it was engaged.
As far as why the lines were off, I think it is stupid to pull both lines off. If you want the front axle to stay disengaged the you should leave the disengage line plugged in. your lucky the axle didn't get stuck haflway engaged and halfway disengaged. Just watch it carefully for the fisrt few days
Finally, If you are in 2wd the front shaft will still spin slowly because the transmission fluid in the transfer case still cause some small amount of energy to get to the front driveshaft.
I learned all of this because I thought my local Ford dealer was trying to rip me off. AND I WAS RIGHT.
I'm glad I could help you out. Get all your fluids changed
Carl Thor
Old Nov 24, 2002 | 06:30 PM
CNTHOR's Avatar
CNTHOR
Old Jan 4, 2003 | 02:03 PM
CNTHOR's Avatar
CNTHOR
to the top
Starwarrior1
Mar 20, 2013 06:19 AM
bennh
Nov 27, 2011 03:35 PM
ebraunusa
Dec 16, 2005 09:02 AM
Big Daddy J
1978 - 1996 Big Bronco
Dec 27, 2004 08:40 PM
mitchntx
Jul 30, 2002 09:14 PM
