questions about convertinvg 302-5.0 pease help
here is the situation i have a a 92 f-150 with the 5.0 and e40D tranny.
last week i lost compression in the #2 cylinder probably a bent exhaust valve fromt he exhaust leak. but there were metal chunks in the pan.
so.
I have the first 302 that was in the my ranger that is a hydraulic flat tappet cam (Crane cam 364381 specs are 488/488-226/226-108 lsa.) now from research i have heard that this cam will not work with the computer becasue of a little too much duration and not the right lsa. also the motor is an older motor so the proted heads are not ported for egr system.
question is what do i have to do to get this older motor run in the truck the stock computer.
possible areas of concern.
using factory distributor would i have to change gear?
egr?
can i bypass egr?
cam?
basically i am on a tight budget and it needs to run by monday.
please an help will be appriciated.
steven
so.
egr?
can i bypass egr?
cam?
steven
