Wheel Specs Dilema
Old May 2, 2004 | 10:11 AM
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Question Wheel Specs Dilema
Does anyone know what the effects would be of installing an aftermarket wheel with a 20mm offset and 5.54 backspace on my 2004 4WD F150? The 17" Weld wheels I'm interested in have those specs. The 18" version (even more $$) have 40mm offset and 6.32 backspace which is what I've read somewhere is closer to factory specs. I do NOT want these things sticking beyond the fenders and would appreciate any knowledge you all to share.
Old May 2, 2004 | 05:37 PM
ScrewBuddy's Avatar
ScrewBuddy
I'd call the local Ford parts dept. and check the stock specs. The problem with non standard offset is it could put unequal stress on the wheel bearings.
Ask the wheel dealer if he'll warranty your bearings. In writing!!
Old May 2, 2004 | 05:44 PM
ieee_raider's Avatar
ieee_raider
This thread might help you:
http://www.f150online.com/forums/sho...hreadid=155267
Old May 2, 2004 | 06:08 PM
NY-Ford-Lifer
Thanks. I have seen that thread. Guess what makes my problem so difficult is that the factory wheel is 7.5" wide and I wish to install an aftermarket wheel that is 8.5" wide. I know what the factory offset and backspacing are but what would those numbers be with a one inch larger wheel?
