Bought a used 01 F350 CC LB 4X4. It has 33" tires that clear with no problems.
My question is if it has been lifted in front? The front spring pack has three leafs. Is this normal, an option, or aftermarket? Rear seems to be stock.
Sounds like you have an add a leaf. There's no way I could clear room for 33's on my stock 350 (although I don't have the X-Spring package). Just be careful, check your tire to see what load range they are. They may not be able to handle what the factory load range E tires are rated at.
P.S.
If you get the chance Hossy and have the ability to do so, set up your gallery. I'd love to see your truck.
Yea if you have 3 leafs on the front then you've got an add-a-leaf on there, and you should be able to fit 33's. I put add-a-leaves on the front of mine and am running 305/70-16 on 16x8's. They fit but you'd need some more lift if you wanted to off road it or anything.
