96 F-150 302 timing?
Old Mar 25, 2004 | 04:35 PM
gcozmo's Avatar
gcozmo
I was wandering if anyone knows if you can adjust the timing on a 96 F-150 302? The repair manuals that I have say that you can't and I don't know why. This model engine has a regular electronic ignition distributer and timing marks on the damper. If you can adjust it, what would it be? Thanks in advance for the help!!
Old Mar 25, 2004 | 04:46 PM
Kemicalburns's Avatar
Kemicalburns
i believe you can just remove the spout connector which i think is on the driver side fender well. but then again your 96 uses obd-II which might not alow this with out diagnostic tools
Old Mar 25, 2004 | 09:48 PM
daerhldgs2's Avatar
daerhldgs2
I believe if you disconnect the spout and adjust- the computer will re-adjust when you reconnect the spout in other words you can't
Old Mar 25, 2004 | 10:42 PM
EPNCSU2006's Avatar
EPNCSU2006
The computer gets timing info from the distributor. It only adjusts from base timing, so you sure can set base timing and change total timing. Disconnect the spout connector and it should default to base timing so you can set it without computer advance.
Old Mar 26, 2004 | 01:34 AM
DW2455's Avatar
DW2455
on your left inner fender well back towards the master cylndr you should find the spout connector tape up in the harnnes, and i belive your base timming is 10 BTDC. DW
