Clunk In my Front End...Please Help...
Old Mar 13, 2004 | 09:05 AM
ExpoBoi99's Avatar
ExpoBoi99
Hello guys, having a problem here...I have a 99 expo. When I drive the truck, only after a few minutes of driving, when I come to a completel stop and proceede to take how i can feel a little bit of a slight "clunkin" noise when i take of. It does it once in a while. Sometimes, it will not do it, and sometimes it will do it all day. I have not changed any fluids yet but plan on it. Also if i put the truck in 4H it will not do it at all, once I swicth out of 4H it won't do it, then after a while a driving it will do it. I was hoping it may be the fluids that need to be changed. Has anyone else had this problem, and solutions would be extremely helpful. I also looked at my trasnfer case and it looks to me like it has been replaced before.
Old Mar 13, 2004 | 11:02 AM
Cobra-Master's Avatar
Cobra-Master
Yikes, sounds like the tranny for sure. Does it feel like it is slipping between gear shifts? Have you checked your tranny fluid level?
Old Mar 13, 2004 | 11:55 AM
ExpoBoi99's Avatar
ExpoBoi99
no the tranny does not slip at all, it rides really smooth, it does not do it a lot, but the problem will go away when i switch into 4h, and then when i turn it off it goes away, but i am thinkin a fluid change may be a start, cause in the morning when i first drive the morning it does not do it, olny when the truck gets warmed up.
Old Mar 13, 2004 | 01:09 PM
MisterCMK's Avatar
MisterCMK
It almost sounds like you have some bushings that have gone bad. Check them all out, and replace if they look worn, or rotten.
