What do I look for good &bad 6c. flathead
Old Jan 28, 2004 | 08:36 PM
classiceeper's Avatar
classiceeper
Question What do I look for good &bad 6c. flathead
I am interested in a1946 ford p-u currently not running and fairly rough. I like it because it is in tact however I know very little about flathead 6 cylinders. I was able to turn engine crank pully with one hand and there was spark plugs in it . Should this be possible ? What else should I be looking ?
thanks!
Old Jan 29, 2004 | 01:23 PM
41Clay's Avatar
41Clay
Welcome to FTE!
Turning the crankshaft with one hand...that doesn't sound good, except for the fact that it turned. That means that there is no compression, either by bad valves, gaskets, or even missing parts, but at least the engine isn't frozen. There's no telling what is going on inside the engine without opening it up.
One thing that you should look for the integrity of the body and frame. Check all parts of the body to make sure that there isn't large amounts of rust through palces such as the bottom of the doors, cab corners, ect. Check and see what might be savable and what might not. If too much of it will need to be replaced then this truck may be better as a parts truck than an actual project.
Starting with a complete truck is good because you'll know how it's supposed to go together and finding replacements will be easier.
Good luck!
Old Jan 30, 2004 | 06:26 PM
classiceeper
Thanks alot for answering my questions ,have a good day.
