is it the battery or alternator
Old Jan 5, 2004 | 05:21 PM
bsmith8's Avatar
bsmith8
Whats the easiest way to tell if battery is shot or is alternator shot on a 1997?Thanks
Old Jan 5, 2004 | 05:27 PM
Franklin2's Avatar
Franklin2
Measure the battery voltage with the truck not running, and then running. Running voltage should be higher(around 14.0 volts). If the voltage is higher running, then the alt is good.
