Sponsored by: Auxito
Hitch w/ dual exhaust?
Old Dec 27, 2003 | 08:50 PM
Brian429's Avatar
Brian429
I have a '03 S'Crew with the Flowmaster Force II Cat-back exhaust on my truck (duals out the rear) I was wondering if this would cause any problems with a hitch being put on my truck. Any guys out there have this setup?
Old Dec 27, 2003 | 10:38 PM
airharley's Avatar
airharley
First question, how much distanct is there from the hitch and the tail pipes? You'll be fine as long as you don't turn too tightly while towing, nothing like bending the tail pipe shut with the trailer. Main reason people don't tow with kind of set up is the exhaust will be pointed directly at what you are towing. You might end up with soot or a slight discoloring of what ever is being towed.
Old Dec 29, 2003 | 04:07 PM
wedge88's Avatar
wedge88
Talking Hitch Problem
I have the Flowmaster Duals Out the back of my 2003 F-150 FX4. There is about 6+ inches on each side of the hitch and the Pipes. You should not have any problem with the mod. Good Luck
