Sponsored by: Real Truck
Accesorie switched line under dash
Old Dec 13, 2003 | 07:09 PM
cwb's Avatar
cwb
As I stated I am looking for a key switched wire under the dash of my 02' 350 to hook up my cb to. Any ideas?Thanks
Old Dec 13, 2003 | 07:32 PM
hang10's Avatar
hang10
grey with yellow tracer.
Old Dec 13, 2003 | 08:21 PM
cwb's Avatar
cwb
Where would I find it?Exactly, I mean?
Old Dec 13, 2003 | 08:54 PM
hang10's Avatar
hang10
If you take off the fuse panel cover, you can access it, not very much but you can get it. If you want a good area, take out the 4 10mm bolts holding the fuse panel on, pull it down and out of the way, beind that, there is a lot of area to tap, as well as all the main ignition wires.
Old Dec 13, 2003 | 09:09 PM
nafzimo's Avatar
nafzimo
http://bulldogsecurity.com/New%20Wir...dfseries03.htm
Old Dec 14, 2003 | 08:35 AM
CLPF350's Avatar
CLPF350
Nafzimo:
Many thanks. I've been browsing this site for some time and that's the first time I have ever come across a complete posting of the wiring colors.
CLPF350
Old Dec 14, 2003 | 04:29 PM
cwb's Avatar
cwb
How can I tell if any of these will handle the new load without waiting for the fuses to blow?
Old Dec 14, 2003 | 09:09 PM
hang10's Avatar
hang10
All your looking for is ignition switched power to a CB?
Old Dec 14, 2003 | 09:58 PM
nafzimo's Avatar
nafzimo
CLPF350 - No Problem! They (BullDog) have the wiring listings available for most vehicles!
cwb - If you are worried about it, you could energize a relay with the key switched wire and then run a separate circuit through the relay for your radio equipment.
Matt
Old Dec 15, 2003 | 12:13 PM
cwb's Avatar
cwb
Matt, Its not a huge concern but I don't want to mess with it again. I thought of the relay but it's just too much hassle if I don't have to.
Old Dec 15, 2003 | 12:55 PM
hang10's Avatar
hang10
I run auxillary lights from mine 55 watts each. I have no problem. I doubt that your CB is 110 watts. While I was under there, I took 350s advice and tapped two more leads for future use, so I dont have to remove the fuse block again, although, that wasn't a major deal. I think your safe.
Old Dec 15, 2003 | 04:11 PM
cwb's Avatar
cwb
Well, now it's done . I used the grey with yellow tracer. On my truck the wires for the steering column are attched to what looks like a large plug(about 2.5" by 1.5")These wires come directly from the fuse block as was said before.I found enough room between there to tap in without removing the block. It works great! Thanks for your help and yes, the correct spelling is a-c-c-e-s-s-o-r-y!
