Sponsored by: Real Truck
2000 F250 Vibrates when slowing
Old Dec 13, 2003 | 01:13 AM
vodoo's Avatar
vodoo
This problem is driving me nuts. Every time I go to slow down my F250 4x4 vibrates. More noticeable at higher speeds. I just had my rotors turned about a year ago. Don't haul anything real heavy or often. Could it be my drive line? Any help or direction to start would be great.
Thanks
Vo
Old Dec 13, 2003 | 06:51 AM
powerstroker250's Avatar
powerstroker250
If it only happenes when applying the brakes then you may have rotor issues again, not uncommon on these trucks.
Old Dec 13, 2003 | 10:04 AM
oppy's Avatar
oppy
If you feel it in the brake pedal, it's probably rotors. If you feel it in the seat, it could be any number of things. Take a look at the u-joints and hanger bearing (if you have one). I had a bad u-joint a little while ago and it acted the same as you describe.
