Sponsored by: Real Truck
Dually axles convert for SRW use
Old Dec 12, 2003 | 06:24 PM
HeavyAssault's Avatar
HeavyAssault
Question Dually axles convert for SRW use
Can you take axles from a dually and convert them to a SRW application?? I'm thinking you can remove the hub ends and swap with SRW ends to use the axles.
Anyone tried this?? Too much work?? Too much $$$??
Old Dec 12, 2003 | 06:31 PM
DCSpecial's Avatar
DCSpecial
Now, I've never done it, but from what I've read on the front it's just a matter of removing the dually spacer but on the rear you'd have to run a 2" spacer (If I remember correctly) so that the tire wouldn't be tucked in.
Hope this helps.
Old Dec 12, 2003 | 10:53 PM
HeavyAssault
Sounds good. I want to upgrade my front, and have found a set for sale. Front and rear from a dually, if I could use the rear that would be a Dana 80 under a SRW truck.
Old Dec 13, 2003 | 04:04 AM
Burnt 1's Avatar
Burnt 1
i was actually thinking of going to a SRW... I dont pull anything anymore or do anything that requires a me to have the dually set up
Old Dec 13, 2003 | 03:08 PM
78f3504x4's Avatar
78f3504x4
I've seen guys do the DRW-to-SRW conversion to foil the Massachusetts lift laws.
Old Dec 14, 2003 | 04:19 AM
m350's Avatar
m350
I am thinking of doing the DRW to SRW conversion on my 04' F-350, a buddy of mine has a set of wheels of his F-250, just to borrow one to see if it fits. Now what to do about the rear fender holes in the bed,,after I remove them,????
I have seen several take-off beds around, now if I could only find one the right colors,,!
10-burnin, 6-turnin, sometime 4 smokin !
Later,,,,,,,,,,,,,Mark
Old Dec 14, 2003 | 04:25 AM
m350's Avatar
m350
Old Dec 14, 2003 | 05:44 PM
Fordman4x4's Avatar
Fordman4x4
78f3504x4,
Is that one of the loop holes in MA? Got any details?
Nelson
Old Dec 14, 2003 | 06:20 PM
78f3504x4's Avatar
78f3504x4
Yes, it is. If your truck (no matter what brand) has a GVW of 10,001# or over, there is no suspension height limit, as you might already know Mass goes by driver's side door height to measure your lifted truck. Once your GVW is over 10,001#, it goes by f/r bumper height of no more than 30". Bumper mods are allowed. At the recent 4XJamborees, I saw 2 lifted Super duty duallys with HUGE lifts (20" and 8") and both had SRW but started out as DRWs. See my buddy's 75C604x4 at this site:
http://hometown.aol.com/highergrounds2/index.html
Old Dec 14, 2003 | 06:31 PM
Fordman4x4's Avatar
Fordman4x4
Yup, I've heard similar...sounds good. I saw some SD's like that up in VT this year too.
Thanks,
Nelson
