1989 F-150 R-12 to R-134a
Old May 30, 2026 | 11:07 PM
DentsideFan's Avatar
DentsideFan
What do I need to swap it over. I made the mistake of putting R-134a in my R-12 system. Old owner said he swapped it but I learned I was wrong. It was not swapped. Now my system has R-134a in it. The compressor kicks on and works. But I would like to switch it over to a better system. What do I need to have it work nicely with R-134a? So far I think I would a need a Compressor, Accumulator, Orifice Tube and O rings. Should I get new lines for it..? Not sure about these systems. Also how do I remove the lines with the refrigerant in it? Do I just carefully remove the lines? I'm not sure if the system leaks.
Old May 30, 2026 | 11:12 PM
DentsideFan
And if I could is there a refrigerant you can run as a alternative to R-12? If I really wanted to I could have a shop vac it out then put a alternative to R-12 in it.
Old May 31, 2026 | 05:28 AM
torq'ta 5 8's Avatar
torq'ta 5 8
There's a few...not sure where to get or if a license would be needed.
Old May 31, 2026 | 05:46 AM
mackendw's Avatar
mackendw
check "The Fix" video out. he does the conversion on a 1990 bronco with a 5.8L engine.
he lists all the components used to do the swap and documents it in the video.
Old May 31, 2026 | 06:38 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would flush the system real good, check for leaks, and refill with R-12.
Old May 31, 2026 | 06:52 AM
manicmechanic007's Avatar
manicmechanic007
You need an "ester" oil to make the 2 oils compatible
You will never get all of the R12 mineral oil out
The ester will make the 2 oils, not form acid, and destroy your system
I'm wondering if any of you have ever been to A/C school?
Speaking to those of you who think you can simply flush the system and replace a part, any part
Buy a retrofit kit that has the fittings and the ester oil, add the oil and add the r134a after evacuating it
Old May 31, 2026 | 07:23 AM
Hit Man X's Avatar
Hit Man X
A small tube condenser or parallel flow will help a pile with heat rejection for the swap and make your system more efficient.
38oz of 134
11oz PAO 68
Red FOT
But if your compressor works, I would just run it as-is but yes 134 and 12 use diff oils.
EDIT - some engines had different cooling fans available, 4.9 for sure. Five versus seven blade, the more across the condenser the better. Either small block can run a 302HO fan over the steel one, moves quite a bit more air!
Obviously verify the fan clutch is good and the shroud is installed.
Old May 31, 2026 | 08:09 AM
torq'ta 5 8
Talking
...it was too late, wrong button.
Old May 31, 2026 | 05:14 PM
tjc transport
i ain't rite
i have been AC certified for close to 50 years.
and i would NEVER convert a R-12 system to R134-A
the R-12 system will freeze you out of the truck.
Old May 31, 2026 | 08:25 PM
DentsideFan
Unfortunately I cannot get R-12. Expensive and you need a license to get it if I can recall correctly. If I could find some I would love to refill it with R-12.
Old May 31, 2026 | 08:27 PM
DentsideFan
38oz of 134
11oz PAO 68
Red FOT
How would a vacuum pump remove all of the oil and refrigerant? Isn't it hard for a pump to remove oil from a system? Would be nice to run the original compressor and lines. May be the case that I have to order compressor and lines with the kit. The compressor kicks on but then shuts off. Probably because the system has R-134a in it instead of R-12. As I said in the OP.
Old May 31, 2026 | 09:40 PM
90project5.0's Avatar
90project5.0
There is a flush that you can push through everything to “clean” it good enough. I did it on another vehicle and didn’t have any issues. I made sure the oil I used had ester oil in it.
Old Jun 1, 2026 | 06:20 AM
tjc transport
i ain't rite
all you need to buy refrigerant is an EPA 609 certificate. cost is around $25. you take it online, and can have the book with the answers in front of you while taking the test.
Old Jun 1, 2026 | 07:46 AM
Hit Man X's Avatar
Hit Man X
Exactly on the 609, plus you can learn something and answer your own questions
It flips on and off as the charge is probably super low. Go buy a nice gauge set from Mastercool or Yellow Jacket so you can see what os going on. Cheapo HF ones will work in a pinch
Old Jun 1, 2026 | 02:32 PM
mackendw's Avatar
mackendw
I'm learnin more gooder by the day on here! thx tips.
