Long term reliability between the 6.2 and 7.3
Old May 25, 2026 | 10:37 PM
Dwwv98's Avatar
Dwwv98
Trailering
Hey all, so im in the market for a newer truck pending a purchase of a camper. Im looking for a 17+ 250 or 350 gas and have found several in my price range. I already know that the 6.2 is as reliable as they come, and definitely am not opposed to getting one,but whats everyone's thoughts on the 7.3 long term and high mileage. I could grab one with 152k on it for a decent price but was wondering if anyone has any input on these motors ar higher mileage? Thanks in advance.
Old May 25, 2026 | 11:01 PM
440 sixpack's Avatar
440 sixpack
I run diesels myself, but there's an outfit locally that runs 7.3's pulling empty containers over the pass and they have some with a lot of miles on them. they've had virtually no problems with them and they plan to buy more. the fuel milage is comically bad that's the only gripe.
Old May 26, 2026 | 05:54 AM
HorizontalHunter's Avatar
HorizontalHunter
Originally Posted by 440 sixpack
I the fuel milage is comically bad that's the only gripe.
Yup, the lifetime fuel mileage on mine is 11.4 mpg but I do mostly around town driving these days. My ‘22 only has 17k on it so I don’t have much to offer on high mileage.
Bob
Old May 26, 2026 | 08:57 AM
DADDYFIGJAM's Avatar
DADDYFIGJAM
If you are looking at trucks with over or around 100k, get the 6.2. The engine is a juggernaut. Of course im biased because I own one!! Oh, and if you can find a 4.30 truck, even better!!
Old May 26, 2026 | 10:15 AM
2021F350's Avatar
2021F350
My 6.2L has 80,000 miles and has been in a shop once, in the last 5 years, for a leaky rear diff seal... Best truck I ever had except for the stock fuel mileage, which now is respectable, with the things I have done to make it like it should have come from the factory...
Old May 26, 2026 | 12:23 PM
Dwwv98's Avatar
Dwwv98
Trailering
Thank you all for the responses, im well aware of the reliability of the 6.2, i have a 2012 with 250k and its been an amazing truck, but sadly rust has gotten the best of it and im soon going to have to part ways with it. I love the 6.2 and how it pulls, i had just seen a lot of posts about how much better the 7.3 was so i figured id ask and get some real world feedback about longevity.
Old May 26, 2026 | 01:06 PM
GAZZILLA's Avatar
GAZZILLA
Some 2022 and older 7.3s had lifter failure.
2020-early 2022s 10 speed 10R140 transmissions had a CDF drum with flawed design which could caused shifting issues. The design was changed and went into production sometime during 2021-2022.
Old May 26, 2026 | 08:28 PM
Dwwv98's Avatar
Dwwv98
Trailering
So will all this being said, seems ill stick with the 6.2 platform. Any major difference between the 11-16 vs the 17+ other than aluminum body and slight torque bump?
Old May 27, 2026 | 12:48 AM
GoinBoarding's Avatar
GoinBoarding
2017+ have a fully boxed frame. F-250 6.2L moved to the 6R100 trans in that year (F-350 kept the 6R140). 2017+ 6.2L also got a torque and power improvement, which includes the IMRC system that infamously clacks/knocks but doesn't seem to actually hurt anything.
Old May 27, 2026 | 05:32 AM
scraprat's Avatar
scraprat
Top Answer: 5
It comes down to your price range. As mentioned and as you know 6.2 is pretty much bullet proof. 7.3 had some lifter issues but was hit and miss. But a 7.3 in a newer truck even with high miles is going to cost some.
Here is my '21' and finishing up a 11 day work week with 250 more miles to finish today. They'll be 263,000 miles on the truck by end of day. Unless something unforseen happens should be near 300,000 by end of year. Normal maintenance, replaced the throttle body around 200k miles. Been a great truck.
If interested.. my maintenance thread in the 7.3 section.
https://www.ford-trucks.com/forums/1...intenance.html
Old May 27, 2026 | 05:28 PM
Split rims's Avatar
Split rims
17 and up had fuel pump issues, long crank times. Also intake runner problems.
Old May 29, 2026 | 09:28 AM
Scott357's Avatar
Scott357
What have you done that actually got you better mpg and how much better? Other than not pushing so hard on the skinny pedal.
Thanks
Scott
Old May 29, 2026 | 09:58 AM
2021F350's Avatar
2021F350
Thanks
Scott
6.2L 10 speed gas milage... - Ford Truck Enthusiasts Forums I will add the 2025 numbers today... I drive it exactly the same, 6 months loaded, 6 months empty, same camper, same roads mostly... A synopsis's below in my sig.
Old May 29, 2026 | 03:17 PM
Joe T's Avatar
Joe T
Either works for a bed camper. 3.73 and stockish sized tires are fine too for that.
The 2017+ trucks are way ahead of the previous models overall. I wouldnt look at prior to 2017 unless you find a great deal.
Old May 29, 2026 | 04:07 PM
Split rims's Avatar
Split rims
Had lunch with my brother today.
Lost his 7.3 to lifter failure @ 120,000 miles.
Oil changes between 3500 and 5000 miles.
Has a 2015 6.2 with over a half a million miles on it.
build date November 2022.
