Lug Patterns
Old May 25, 2026 | 02:07 PM
BobcatNT's Avatar
BobcatNT
Lug Patterns
Are 8 lug Dodge wheels the same pattern as 8 lug 1992-1996 Ford 250-350?
Old May 25, 2026 | 11:10 PM
HydroDog's Avatar
HydroDog
The Dodge pattern is the same for those years but since the Dodge uses a cartridge bearing wheel hub the offset is different.
If you want to use the Dodge wheels you would have to use some bolt on wheel spacers. Without the spacers, the wheel hits the tie rod before it’s bolted up tight.
Old May 26, 2026 | 10:58 AM
BobcatNT's Avatar
BobcatNT
Thanks
Old May 26, 2026 | 06:38 PM
cougrrcj's Avatar
cougrrcj
CHECK BEFORE YOU BUY!!!
Don't forget the center bore of the wheel - they may be different. Ford uses a 124.9mm or 4.92" 2000s Chevy used a 116.7mm center bore. I'm not sure about Dodge...
GM, Dodge and Ford all used the same 8 x 6.5 bolt circle (Ford since 1953!) until the '99 Ford SuperDuty took it Metric at 8 x 170mm (6.7")
Be advised that the 2005-newer DRW SuperDuty (and 2019-newer Dodge duallys) are 8 x 200mm bolt pattern
Old May 26, 2026 | 07:04 PM
BobcatNT's Avatar
BobcatNT
Thanks. I enlarged the centers on some VW trailer wheels to match an odd axle I had with my Bridgeport and it was more trouble than it was worth.
pintoches
Yesterday 07:13 AM
Hudson High
Oct 17, 2015 02:55 PM
magnus
Apr 13, 2001 09:26 PM
