1994 F250 351w Crank No Start, No Fuel Pressure at Rail
Old May 23, 2026 | 08:33 PM
Ford POWERSTROKE 7.3l's Avatar
4wd High
The truck cranks, but doesn't want to start, and there's no fuel pressure in the rail. I know the midship tank fuel pump works, and the fuel filter isn't clogged. but it's just been kicking my butt
Old May 23, 2026 | 09:59 PM
90project5.0's Avatar
90project5.0
Check for pressure before fuel filter and see what you get. Shorten where might be the problem. Have you checked for voltage at the pump connector? Do you hear the pump priming?
Old May 24, 2026 | 02:56 PM
4wd High
I did ensure that the fuel pump works, and the fuel filter isn't clogged, but I just have no fuel pressure in the rail
Old May 24, 2026 | 09:01 PM
90project5.0
Jump the fuel pump test port, turn key to run position and see if you get fuel to the rail. If not, pull the tank selector switch and verify it’s sending power out.
Old May 25, 2026 | 11:15 AM
4wd High
Sorry stupid question, how do I test the selector switch?
Old May 25, 2026 | 01:09 PM
90project5.0
look at the wiring diagram for it. Check Power going in and out on each tank when selected at the switch. Mine went bad not too long ago.
Stupid questions are the ones not asked!
Old May 25, 2026 | 01:39 PM
4wd High
thank you, I checked the switch, but its working fine.
jwillman
19
Dec 31, 2020 01:16 PM
Shawn Paris
Aug 2, 2016 10:56 PM
JoeVR5
Sep 28, 2015 12:47 AM
78250custom
May 22, 2009 10:05 AM
Koji2528
Bronco II
Dec 3, 2004 02:56 PM
