Sponsored by: Real Truck
No running lights on trailer
Old May 23, 2026 | 01:33 PM
dkoutfitters's Avatar
dkoutfitters
3rd Gear
I have a 2011 Ford F450 that has the fifth wheel package as well. Running lights on my trailer we’re working before. The only thing functioning now is the hazard turn signal and brake lights. I’ve replaced the relay as well as the fuse with no luck. I’ve also replaced the seven pin and four-way adapter on the bumper assembly. Any other thoughts of what the issue might bewould be greatly appreciated.
The trailer lights work, on my son’s Dodge, as they should.
Old May 23, 2026 | 01:46 PM
marksman76's Avatar
marksman76
Ground wire connections on trailer or to your 7 pin could be places to start.
Old May 23, 2026 | 02:42 PM
apache84's Avatar
apache84
Were the fuses you checked burnt? Next thought would be the tail light wire came out of the tab in the female/truck end trailer socket. Typically a tiny little screw holding the electrical part into the body. Pull the screw, and with a enough slack in the wiring you should be able to push it out of the body and check/clean/tighten where the wires are landed.
Old May 23, 2026 | 03:45 PM
dkoutfitters
3rd Gear
Fuses were not burnt. I'll check the connector. I should mention, same result if trailer connection is on the 5th wheel and on the bumper.
Old May 23, 2026 | 03:46 PM
dkoutfitters
3rd Gear
I'll take look at the ground near the 7pin. Hoping it is the one on the drivers side rear frame rail.
Old May 23, 2026 | 04:58 PM
marksman76's Avatar
marksman76
Run a test ground wire from truck frame to trailer frame to see if anything changes.
Smokeat
Nov 17, 2024 05:23 PM
Melanie Ross Thaxton
2009 - 2014 F150
19
Sep 25, 2023 12:29 PM
Dennis72355
All Things Towing
Dec 14, 2021 08:23 AM
HKusp
13
Apr 7, 2014 09:56 PM
iez44
All Things Towing
Sep 6, 2013 02:43 PM
