1961-1966 ford truck parts
For Sale
Miscellaneous
  • Price
    $999,999
  • Location Hopkinton, MA, 01748, USA
  • Condition Used
  • Compatibility
Make Model Year
Ford 1/2 Ton Pickup 1961 - 1966
Description:
1964 short bed truck - cab and bed with clean title with 226 engine
Parts from 1961-1966 ford trucks
tons of parts from 6 trucks parted out f100, f250
C3AR 7006 E. 3.03 3 speed manual all synchro transmission, initially installed in full sized Fords and F100/250's
1964-223 engine
1964 tail gate
1964 short bed, bed needs work. factory shift on the floor,.
cab parts-will cut out pieces if you need them
1964 short bed, bed needs work. WARNER T98 TRANSMISSION factory shift on the floor,
ford 9" rear 3.89
Pair of west coast mirrors- painted
cap for short bed
1964 truck manual for glove box
Ford Steering box ID number: AJ-3580-B = Ford part number: C1TZ3580A.Fits: 1961/64 F100 2WD Steering Gearbox C3TR 3550 A
really nice original radio and speaker, for rebuild. AM non working radios with *****.
headliner trim
two speed wiper motors and switchs-1964 and 1966
300/240 power steering alternator bracket and pulley and crank pully
1966 F100 CAMPER SPECIAL PARTS INCLUDING A BRAKE BOOSTER AND BRACKET FOR POWER BRAKES
spare tire bracket
49-64 Pickup rims wheels, 16", rim, wheels
C5AE-10039-C alternator bracket
FLASHER EMERGENCY SWITCH-complete set up with the harness. needs to be cleaned up. may need part number C6TZ-13A350-A-THIS PART IS STILL AVAILABLE NOS
two pair of fender bolt access covers, one Fender bolt access cover for passenger side
i have on seized 223 engine, good for parts
I have two 240 engines. 1966 240 I6 6 cylinder with head. Two completely dismantled, but have all parts.
many 2603202 ford manual transmissions, toploader, three speed transmissions, two with short tail and one with long tail
240 head
headers for 240/300
Locking spicer rear end 44.1 3.732-3m - Jeep guys, rock crawlers
oil bath air cleaner
1963, 1964, 1965/1966 heater
1962-1964 straight front axle
NP 435 shifter, \
battery box,
original folding jack rod/arm
front windshield window trim
cab parts
1961 1962 1963 1964 f100 with 240 inline 6 shift arms and brackets for three on tree steering transmission linkage f250
C3TZ-7326-E. 2nd/3rd Shift Rod, C1TT-7328-F .. 1st/reverse shift rod 2WD 3 speed M/T 3 speed M/T with Overdrive. With transmission shift lever​s
window channel guide bracket. both sides
Emergency brake parts
clutch brake pedal assemblys
Rear drums, backing plates, brakes, emergency parking brake lever, complete, both sides 1963, 1964 1966
washer sprayer,
deluxe delux heater control valve, cables and bracket
glass,
hub caps, wheel covers
lower dash trim
352, 240 engine perches.
hood hinges
visors
flareside flare side license plate light
dash trim both long and short pieces
dash switches.
window regulators
352 water pump and brackets.
headliner parts
windows,
trim
Steering box manual for Cowl steer rat rods c5tr-3550a1
dome light
many other other parts, bolts, fasteners etc.
flareside parts, chains etc cross rails
Bell housing C5TA-6394 a This will bolt up to a 351W, 302, 289 or 300 straight 6 engine,
Bell housing. D1TA- 6394-a-fits '66 through '73 Fords with small block V-8 or 240/300 6 cylinder motors with 6 bolt mounting and running a 3 speed or 4 speed Top loader . Works on car or truck. 6 1/4in deep and will accommodate the 164 tooth, 14.25 dia. flywheel so you can run an11in. clutch
Manual transmission parts
other parts also for these trucks
headliner trim
3 on tree three speed shift rods
Deluxe heater, 1965/1966 heater
1963, 1964, 1965 grill
interior door trim three complete matching set of 6 pieces. single pieces also
