Sponsored by: Auxito
Fuel Pump Relay Fuse #
Old May 1, 2026 | 07:16 PM
F150_4x4's Avatar
F150_4x4
Just looking for some extra security precautions...
If I go down to the 🇺🇲 with the truck and go to a mall/gym for a couple hours ...
I don't want to risk losing my truck.
It's old but still in great shape.
It's a 2000 4.6 V8 F150
Is it bad for the electrical system if I pull the fuel pump relay fuse before parking it ?
I mean, it's both costly/takes time to have a kill switch installed.
The club is useless ....unless I use a tire boot.??
I'm thinking just pull the fuse ...
What fuse number is it ?
Also the outside temperature digital display stopped working all of a sudden...
Is it a fuse or something else that burned out ?
Old May 2, 2026 | 07:24 AM
projectSHO89's Avatar
projectSHO89
Your truck (presumably) already has the PATS system. No one is going to start the engine without the pre-programmed key.
I suspect you're over-thinking this....But, since you asked, it's fuse F10 in the under hood fuse box.
Old May 2, 2026 | 11:40 AM
F150_4x4's Avatar
F150_4x4
So to be clear ...
It has the PATS system. I see the "Theft" light on the dash constantly blinking when vehicle is in park and engine turned off.
I don't use the remote keyless entry for it.
If I have only the key on me or better yet in a Faraday pouch, am I even better off(safety wise) ?
If I go down to the States and I'm in a gym for a couple hours or mall I don't want my truck getting stolen in the lot.
Old May 2, 2026 | 10:01 PM
F150_4x4's Avatar
F150_4x4
I also read that an OBD2 lock is a must.
That's a vulnerable area of the vehicle for car thieves to exploit.
Old May 3, 2026 | 07:00 AM
projectSHO89
You're WAY too obsessed about this....
Just lock the doors and put the key in your pocket then go do whatever you need to do.
jdaxford
Aug 14, 2022 03:21 PM
F150_4x4
1997 - 2003 F150
Mar 24, 2022 06:42 AM
Padre
Oct 17, 2007 06:58 AM
tioga
Oct 25, 2006 11:34 AM
darrengj
13
Jan 2, 2006 12:42 AM
