Floating Axle in Dana 44 - Should I replace it?
Old Apr 27, 2026 | 05:04 PM
joaquin1970's Avatar
joaquin1970
Trailering
Question Floating Axle in Dana 44 - Should I replace it?
Hello everyone,
I am back at working in my 1969 Ford F-100, and I’ve noticed that the rear axle has been swapped for a floating axle setup.
I’d appreciate some guidance on the following:
  • Would you recommend switching back to the original rear axle, or is it better to keep the current floating axle (see picture 1 and 2) ?
  • If I keep the floating axle, I’ll need to get compatible wheels.
    • What wheels or hubs would you recommend for this setup? Can I mill/enlarge the original wheel to the diameter of the floating axle end (pic 3) ?
    • Any suggested wheel and tire size combinations that work well?
  • My initial plan was to go with the original wheels and hubs (see picture).
    • Is it possible (or practical) to adapt those original-style wheels to the current floating axle (pic 3 and 4) ?
I’m new to this, so any advice or recommendations are really appreciated, I was aiming to get something like pic 5.
Thanks in advance!
Picture of current wheel setup with floating axle
Picture of current wheel setup with floating axle (picture 1)
Current axle setup
Current axle setup (pic 2)
Original wheel 1969 f100 - F100 made in Argentina variant
Original wheel 1969 f100 - F100 made in Argentina variant (pic 3)
Wheel hubs F100 1969 Argentina variant
Wheel hubs F100 1969 Argentina variant (pic 4)
What I am currently going for.
What I am currently going for. (pic 5)
Old Apr 28, 2026 | 07:54 AM
fe390pc's Avatar
fe390pc
That could be an original dana 60.3. It was a rare option. I like the wheels and hub caps though.
Old Apr 28, 2026 | 09:44 AM
manicmechanic007's Avatar
manicmechanic007
Looks like an OLD 5 lug 3/4 or 1 ton axle (probably a real good axle)
I'd run that axle until you wear out those old split rim bias ply tires
Then switch to a 9 inch rear end and some conventional tubeless tires (or buy some non-split rim wheels that fit that axle)
Nobody really plays with those split rims for cheap anymore, just finding tubes and tires for the split rims will cost as much as a junkyard 9 inch rear end with tires on it
Old Apr 28, 2026 | 02:04 PM
Crop Duster's Avatar
Crop Duster
I agree with fe390 that is most likely a Dana 60.3 it should be limited slip keep it they are rare. They only came in two ratios 3.54 or 4.10-1.
Old Apr 30, 2026 | 08:36 PM
joaquin1970
Trailering
Thanks everybody for the answers!
I will keep it as is then - Looks like it is a dana 60.3 mod they do here in Argentina to carry 1 ton on the bed .
I just measured the hub and it measures 3.4 in. Looks like I will have to take the old wheels to the town mill shop to enlarge the hole diameter to make it fit, It will need like ,2 inches off, any thoughts here I should be aware of?
Measure of hub in CMs.
Measure of hub in CMs. (Diameter:≈3.7 inches (94 mm))
I also noted that the original wheels are fitted with a 650-16 tyre. Which is the recommended modern tyre size for this wheel from your experience?
would a 245 x 65 x 16 fit? is it too wide?
Original wheels with 6.50-16
Old May 1, 2026 | 05:26 AM
manicmechanic007
You know how dangerous dealing with split rims is, right?
I'd get conventional wheels or sheet can the axle
MRGarrett
Jan 26, 2024 10:48 PM
jhelliot
Aug 11, 2022 03:13 PM
Nicxt44191
23
May 5, 2019 12:49 PM
packrat56
Dec 22, 2007 10:56 PM
