P0401 EGR Flow Insufficient Detected
Old Apr 25, 2026 | 05:31 PM
Pitcrw6's Avatar
Pitcrw6
Hey fellas, got a 05 with the 4.6L and got the P0401 DTC code. Would this be the EGR valve is plugged up and can it be cleaned or does it need to be replaced? Also where is it on the engine. Here's the pics of my scanner.
Old Apr 25, 2026 | 08:01 PM
LEEDSnDeed's Avatar
LEEDSnDeed
I think the valve on those has the DPFE built into the valve.. Back when the dpfe and the valve where seperate there were some test to figure out which was the issue..On those since it all together most times its going to be the valve assembly since both DPFE and valve are the same thing.. there are other test, but a bi-directional tool would be needed for those.. The valve is not far from the throttle body on the driver side
75 f250 camper special
Apr 15, 2024 11:11 PM
SwampJYDod
Jul 19, 2021 02:34 PM
Missionstreet
Nov 30, 2020 03:22 PM
Patrick Johnson
Feb 21, 2020 07:58 PM
Volvo92906
Oct 31, 2009 08:42 PM
