Low battery voltage after turbo change
Old Apr 20, 2026 | 02:31 PM
ChassisCab's Avatar
ChassisCab
So, several months back, i put a set of UDP 205/30 injectors in along with a PHP hydra in my 97 powerstroke. I held off on doing the turbo until the kc 300x gen 3 came out. So, after injector install, she ran beautifully and no battery drain. Ran it for about 2 months with no issues. Then, finally KC dropped their turbo, which is a OBS to superduty turbo conversion. Did the whole install and now my batteries show low voltage.....like below normal and it takes forever to get back to where it usually is, if it does at all during my 20 minute drive to/from work. Usually reads about 3/4 on dash. I don't see any pinched wires and since I didn't need to pop the valve covers, I know it's not anything in there. The only thing really is does the EBV wire need to be capped off, could that be causing the battery drain? I do have it taped off. Thanks
Old Apr 20, 2026 | 02:39 PM
knottyrope's Avatar
knottyrope
GPR always on can happen
if its not that when was last time you cleaned your terminals?
cleaning tips here and battery test
https://www.ford-trucks.com/forums/1...ou-cranky.html
Alts can go bad or the connectors going to them can get corroded.
Have 12v at the alt lug? There is a fuseible link near starter realy that can break with age
Old Apr 20, 2026 | 02:44 PM
ChassisCab's Avatar
ChassisCab
GPR is new, White Roger's and all connections are good. The battery posts and cables are clean......I clean them every time I disconnect them, and did it again 2 days ago. Same result.
Old Apr 20, 2026 | 03:46 PM
97-psd's Avatar
97-psd
Have you checked the alternator connections? The top connector can take some abuse when you are working on the truck.
Old Apr 20, 2026 | 03:57 PM
ChassisCab's Avatar
ChassisCab
I gave it a wiggle, but did not disconnect/reconnect it. Would the EBV wire not being capped be a problem?
Old Apr 20, 2026 | 07:21 PM
97-psd's Avatar
97-psd
It shouldn’t be. Mine is not capped and never has been.
Old Apr 20, 2026 | 09:52 PM
ChassisCab's Avatar
ChassisCab
Hmmmm, well I will keep trying. Thanks
Old Apr 21, 2026 | 08:07 AM
Hit Man X's Avatar
Hit Man X
See if alt is putting out juice at the lug on it. Then go to the solenoid to check Then go to the battery.
I would not rely upon the dash gauge
Old Apr 21, 2026 | 01:29 PM
ChassisCab's Avatar
ChassisCab
I can also tell that it's low on juice......harder to crank and it puffs white smoke on startup and clears up after about 10 seconds. After I put my injectors in and before turbo, it started beautifully and no smoke......so I definitely don't have as much juice as I should
Old Apr 21, 2026 | 01:32 PM
Hit Man X's Avatar
Hit Man X
Totally could be unrelated to the upgrades, bust out that DVOM and check voltage. Talking more time to grab the tools, a drink, and open the hood.
Hell, weak batts tax the alt enough you see low voltage.
Old Apr 21, 2026 | 03:17 PM
ChassisCab's Avatar
ChassisCab
Both batteries are brand new this last fall
Old Apr 21, 2026 | 03:24 PM
Hit Man X's Avatar
Hit Man X
Man, at this point means nothing. I have have fresh that are weak starts, no clue why. I assume **** build quality. Pain in the *** to swap.
Buy this lil guy or hit parts store. Guy on 87-96 page recommended BELOW IMAGE
Edit - Link was bad.
Old Apr 21, 2026 | 07:40 PM
97-psd's Avatar
97-psd
Link doesn’t work on my end. Just some random discount clothes/crap website
Old Apr 21, 2026 | 07:52 PM
Hit Man X's Avatar
Hit Man X
Oops, prob something on my end. Image below.
Old Apr 21, 2026 | 08:04 PM
ChassisCab's Avatar
ChassisCab
But why would the batteries be effected after a turbo change. It was fine before, both batteries new. Not seeing pinched wires that I can tell. Could all of the penetrating oil I used to soak the bolts have drained down towards the started and caused this?
