Loss of power/fuel starvation? at a loss.
Old Apr 13, 2026 | 09:48 AM
731_1997_7.3's Avatar
731_1997_7.3
4wd Low
First time posting, long time lurker. I have a 1997 7.3 XLT 4 Door SRW 4x4. I'm at a loss. I am losing power, its acting like it is out of fuel after driving for 10 - 15 mins. under a load. within the last year I have replaced the injector orings, the rear abs valve, the fuel lift pump, orings in the fuel bowl, selector valve on the dash (double checked it was for a diesel), I also replaced both tanks, sending units (with shower heads), and vents on the tank. I had trouble getting the sending units to seat correctly (I think). I have good fuel pressure at the schrader valve ( i have not checked it since replacing the fuel pump, I did that last night). after replacing the fuel pump I drove it and it drove better (faster reaction to throttle) for 30 mins, which is longer than before. It then died like before and the restart was as difficult as before the replacement. I am unsure what the issue is at this point. Do I continue down the fuel system or do I redirect to the HPOP? I have forscan to collect data, just not sure what to even look at at this point. TIA.
Old Apr 13, 2026 | 12:19 PM
knottyrope's Avatar
knottyrope
Need to know cranking PSI of fuel and running PSI
Do you have any blockages in the fuel lines?
clean these?
https://www.ford-trucks.com/forums/1...-to-clean.html
Old Apr 13, 2026 | 12:26 PM
731_1997_7.3
4wd Low
I cleaned everything related to the fuel bowl, screens, new gaskets, and the bowl itself. I haven't been able to get a psi reading while driving but the crank is 40 psi if I am remembering correctly. It was within whatever the range is, I remember looking it up and checking mine and not being concerned with it. I thought it was losing it during driving. I ordered the adapter and it was too large for the port (Super duty adapter maybe?) but at that point I just bought the pump. I should say I did not change the supply line or banjo bolt, there was no leak after reinstalling.
Old Apr 13, 2026 | 01:07 PM
knottyrope's Avatar
knottyrope
Can you do a run with foscan logging?
IPR% duty cycle
IPR pressure
RPM
Throttle pos
Inj Pulse width
Old Apr 13, 2026 | 04:04 PM
731_1997_7.3
4wd Low
IPR% duty cycle
IPR pressure
RPM
Throttle pos
Inj Pulse width
yes, I will try to run that this afternoon once I’m off work.
Old Apr 13, 2026 | 07:53 PM
731_1997_7.3
4wd Low
IPR% duty cycle
IPR pressure
RPM
Throttle pos
Inj Pulse width
so ran it & it died after 5-10 mins of pushing it. 55-60 mph. What numbers am I looking for? Or what would be the best method to provide my data, screenshot? Or just the range?
Old Apr 14, 2026 | 08:51 AM
knottyrope's Avatar
knottyrope
send us the csv file from the run and we can work with it
Old Apr 14, 2026 | 09:03 AM
731_1997_7.3
4wd Low
Forgive me, but how do I send it as a file on here? I have formatted it to a cvs already. I just got it opened in excel.
Old Apr 14, 2026 | 09:13 AM
731_1997_7.3
4wd Low
I also got a code for UVCH for the first time. p1293 and p1294. But here is the data, I had several different monitors going.
File Type: csv
Old Apr 14, 2026 | 12:51 PM
knottyrope's Avatar
knottyrope
i see a high pulse width trying to maintain idle at the end
Common Causes for High Pulse Width (7.3L Powerstroke)
  • Low High-Pressure Oil (ICP): If the HPOP cannot maintain 500+ PSI at idle, the PCM increases pulse width to compensate.
  • Failed ICP Sensor: A malfunctioning sensor sends bad data to the PCM, leading to incorrect fueling commands.
  • Faulty IDM (Injector Driver Module): The IDM can fail, causing high-to-low side open codes or inconsistent injector operation.
  • Injector/Wiring Issues: Wiring harness issues (especially under the valve covers) or stuck injectors can cause the system to malfunction
unplug the cable to ICP on drivers head, if idle gets better then its the sensor
THats for boths sides, wonder if the 42 pin connector has water in it or the IDM
Old Apr 14, 2026 | 06:39 PM
731_1997_7.3
4wd Low
Unplugged the ICP there was a noticeable pick up in the idle. It sounded better. Other than driving it until
it dies i’m Not sure how else to check it. I will replace that sensor & see in a few days I guess. Thank you!
Old Apr 15, 2026 | 09:55 AM
knottyrope's Avatar
knottyrope
get a FORD OEM one and not aftermarket
Old Apr 22, 2026 | 07:58 AM
731_1997_7.3
4wd Low
Finally got the ICP sensor in and around to installing/testing. I will attach my new data. The issue is still there, although it does seem to run better until it dies. I was messing around with the forscan and I got several new dtc P1280, P0603, P0344, and P0340. I may not have followed the procedure correctly. I will recheck it.
File Type: csv
Old Apr 22, 2026 | 09:44 AM
knottyrope's Avatar
knottyrope
  • P1280 (Injection Control Pressure Circuit Low): Suggests the PCM sees low or no pressure from the ICP sensor.
    • Causes: Faulty ICP sensor, damaged pigtail/wiring, or low high-pressure oil.
  • P0340 & P0344 (Camshaft Position Sensor Circuit/Intermittent): Indicates erratic or missing signals from the CPS.
    • Causes: Faulty CPS, wiring harness chafing (common on 7.3L), or loose connector.
  • P0603 (Internal Control Module Keep Alive Memory Error): Often triggered by disconnecting batteries or a tuner/chip, but can indicate PCM issues
Ill look at the CSV soon.
Old Apr 22, 2026 | 09:56 AM
knottyrope's Avatar
knottyrope
EBPV 2 to 14 isnt normal and wonder if there is a wiring break in the harness.
Also the IPW seem to go higher when warm.
Is your fuel filter meadi dark?
