Sponsored by: Auxito
Brake rotors
Old Apr 9, 2026 | 08:04 PM
teamjnz's Avatar
teamjnz
Brake rotors
I will be changing my front brakes this weekend. I am looking at the regular stores online and only see rotors with the hub. I just want to change the rotors. Are the rotors for the 4X2 truck only integrated with the wheel hubs?
2002 F150 XLT, 5.4L 2 wheel drive
Thanks
Old Apr 9, 2026 | 10:25 PM
BareBonesXL's Avatar
BareBonesXL
Originally Posted by teamjnz
IAre the rotors for the 4X2 truck only integrated with the wheel hubs?
Thanks
Yes. The front rotors and hubs are combined on the 2WD trucks.
And I think that most of them also come with outer bearing races already installed. So you have to decide if you want to remove the races and install a matched set or trust that mix and match will work because specs are set across the bearing industry. I haven't bought new yet but I've wondered about that. Maybe one of the pros knows.
If I was selling rotors I'd sell them with bearings, complete, as a set. But nobody seems to do that.
p.s. there are still shops out there that will turn rotors. Usually cheaper than new and you don't have to mess with bearings unless they're worn. Many NAPA's still have brake turning machines in the back. I had mine done there and they came out fine.
Old Apr 9, 2026 | 11:23 PM
teamjnz's Avatar
teamjnz
I called the local Oriellys if they have parts in stock then asked if he could refer me to a shop that turns pads. To my surprise they have a turning machine. Planning on that option first.
Old Apr 10, 2026 | 07:50 AM
manicmechanic007's Avatar
manicmechanic007
Smart move
2 schools of thought for you to think about
One: The initial warp, (thickness variation or lateral runout) if machined out, the rotor will last quite a while once you true up the warp
Two: Turning them make them thinner and they will warp again quickly
We / I used to have real good luck turning Taurus rotors, F250's not so much
Your 4x2 would be worth the effort IMO
Let us know how long they last this time around
I replace mine on my 4x2 van every 3 or so years and do not turn them, course I drive like Parnelli Jones
Old Apr 10, 2026 | 12:48 PM
BareBonesXL
What do you do about the bearings? Do you just put the old bearings in the new races in the new rotors? Or mismatch brands with new? Not a critique, just curious.
I put a new bearing in an old race on my old Pathfinder after I hit a curb and bent the retainer, causing it to squeal at times. No problems.
Old Apr 10, 2026 | 07:06 PM
manicmechanic007
Other way around on my 94 van, new races in new rotors, then re use the old bearings
(So far I have just swapped my bearings over to the new rotors which have new races)
I pack them and drive; I have right around 110k and the bearings keep looking good so far
Old Apr 11, 2026 | 06:14 PM
Hit Man X's Avatar
Hit Man X
I always try to turn rotors, flywheels, whatever...especially if known good. Big issue here is finding the one, maybe two folks at the auto store than can run a brake lathe. Total pain to turn a drum as they cannot measure proper
When I purchased my Screw back in 2020 or so the fronts were down to around 0.775", new spec was about 1.110" or so. Still original from 2001...all was O.E. Ford, amazing. I just did new bearings, Timken I think, with fresh rotors...probably Raybestos.
In any event, follow O.E. procedures for torquing. I have near 30k on my brake job with zero issues post that. Rears are a snap as they are floating, check the axle seals. Mine were weeping around 200k. That killed my ebrake shoes, easy fix and great having them operable again
Old Apr 13, 2026 | 07:59 PM
teamjnz's Avatar
teamjnz
Smart move
Both of the rotors were warped a little. The measured 1.02 thick before turning. If I recall .973 thickness is the discard thickness. I didn't measure afterwards. I repacked the old bearing and reinstalled.
Normal braking now, no more wobbles.
Old Apr 15, 2026 | 08:31 AM
Hit Man X's Avatar
Hit Man X
Depending upon the brand, I can usually have a turn or two from the rotors. O.E. seem to run longer, probably superior material.
Suppose it also depends upon pad material, I recall organic is very soft and ceramic is pretty hard on them.
bigcountry1009
Mar 21, 2009 08:05 PM
CTSteve
Apr 7, 2004 06:39 AM
khmorse
Dec 21, 2003 07:44 AM
MybestfriendisaFord
Oct 10, 2003 01:40 PM
