Truck only starts while OBD2 is connected.
To make a long story short, ive been having issues with my truck for over a year. I originally thought it was hpop related. I put in a riff raff hpop in it, new oem ipr and icp. Truck would randomly surge and studder after all of that was installed, and sometimes die like I shut the key off. (Majority of this would happen at idle, rarely while driving) it would also have very hard starts.
Then about a month ago I went out to start it, and all it would do is crank. No smoke, nothing. I am getting fuel as well. I have a driven diesel electric fuel pump on it. Pump is on and has fuel at the rail.
I ordered a OBD2 scanner to check my pressure and such at cranking and the truck started.. still having the original issue of dying and studdering. But it DID start..
So I tried removing the hydra tuner I have and that didnt make a difference either.. (truck ran significantly worse actually..)
After performing a buzz test i do have the following:
P1272 cylinder #2 high to low side fault
P1274 cylinder #4 high to low side fault
If this was all truly injector related wouldnt it just misfire and not just die like I turn the key off? And wouldn't it still start? (Also, injectors probably have 20k-25k miles max)
I even tried a different IDM. I still had the original crank no smoke no start issue..
I am really stumped with what is going on here.. I hope its just something dumb..
If anyone has some insight on what I could do here, I would greatly appreciate it!
2 nd 4 souinds like a wiring harness issue to me or UVCH, going to take some work to look into it
ohm out with chart in this link
https://www.ford-trucks.com/forums/1...load-test.html
Swap PCM relay out with one next to it? Relay contacts can wear out after years.
Sorry, forgot to post the year.. its a 96, I cant remember for the life of me what injectors are in it..
Thanks for that chart. that is probably the next thing to do.
