Turn signals
Old Apr 4, 2026 | 08:22 AM
tico47's Avatar
tico47
Turn signals
I added turn signals to my 49 F1 last year. For some reason I was never able to get the indicator light on the signal switch to work. I have made sure that everything is grounded. Has anyone else had this problem ? If so how did you correct it? Thanks in advance for your input
Old Apr 4, 2026 | 08:35 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
If I recall properly, you have a 7 wire setup of this nature:
Make sure you have 6V components if 6V and 12V if 12V. This includes the 3 prong flasher unit and the lamps (including the one in the stalk!). Also, as it calls out, you need to have a great ground to the stalk.
Old Apr 4, 2026 | 08:36 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Others might chime in but do you have any LED lights installed anywhere on your truck?
Old Apr 4, 2026 | 08:38 AM
pineconeford
Bmoran4 makes a great point. If your column is painted you have to make sure the switch makes great contact.
Old Apr 4, 2026 | 10:21 AM
tico47's Avatar
tico47
Everything is hooked up as per your diagram. I will recheck the ground on the colum. Once again thank you for your advice
Old Apr 4, 2026 | 10:34 AM
tico47's Avatar
tico47
No Led lights, everything is still 6 Volt
Old Apr 5, 2026 | 07:13 AM
55F250's Avatar
55F250
AirForceVet
i had an issue with my column mounted turn signal, Chieftan I believe, everything was working fine, then one day the indicator light quit working, a couple of days later a fuse blew. I lost all indicator lights. I traced it back to the turn signal switch, the wire going to the indicator socket had come loose and grounded causing the fuse to blow.
Old Apr 5, 2026 | 09:25 AM
tico47's Avatar
tico47
Originally Posted by 55F250
i had an issue with my column mounted turn signal, Chieftan I believe, everything was working fine, then one day the indicator light quit working, a couple of days later a fuse blew. I lost all indicator lights. I traced it back to the turn signal switch, the wire going to the indicator socket had come lose and grounded causing the fuse to blow.
Okay thank you for that input. When i get the truck back from winter storage at the end of the month I have a list of things that I want to finish up.
And by the way, thank you for your service to this country
DoofusOfTheDay
2015 - 2020 F150
Jan 1, 2023 07:05 PM
87tallboy
18
Dec 10, 2022 05:19 PM
bks976
Jul 12, 2015 05:06 PM
plowking
Electrical Systems/Wiring
Dec 2, 2008 07:14 PM
sigtauenus
Jul 23, 2006 03:30 AM
