Modular V10 (6.8l)
2001 Ex. Rough Idle / Miss Only At Idle In Drive
Old Feb 16, 2026 | 03:47 PM
LeftCoast6.8's Avatar
LeftCoast6.8
Hi All,
I'm having an issue with my 2001 6.8L 2WD. I have a random rough idle or miss but only when it's idling in drive. In neutral or park it goes away. Doesn't miss while driving or slowing down.
Plugs and boots only have about 7K miles on them. No codes showing.
Thanks
Old Feb 23, 2026 | 11:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Less load and/or more revs will often hide a misfire.
Can you scan it to see if any misfire counters are accumulating? . . . and if there are codes stored?
Old Feb 26, 2026 | 10:56 PM
LeftCoast6.8
No codes at at all using multiple scanners and OBD Fusion with the enhanced Ford add on.
Old Mar 2, 2026 | 04:11 AM
charlie g's Avatar
charlie g
FTE Community Team
compression test time, followed by checking injector flow, could be a worn valve guide letting the valve rock at idle off the seat or a sticking shut injector
LeftCoast6.8
Feb 27, 2026 06:19 AM
dirtrider02
Escape & Escape Hybrid
Mar 16, 2024 08:45 PM
F0rdc0wb0y
28
Mar 13, 2022 09:29 AM
Nrochwal
6.4L Power Stroke Diesel
Aug 22, 2020 07:54 AM
Nrochwal
Jul 11, 2020 03:46 PM
