2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
2018 Lincoln Navi Welcome not working anymore
Old Nov 26, 2025 | 08:52 PM
Mortipheus's Avatar
Mortipheus
3rd Gear
My 2018 Lincoln Navigator Reserve Lincoln WELCOME was working but has stopped. The Key fob batteries are new. The System check shows WELCOME light and running boards are supposed to work when you walk up. But nothing happens now until you unlock the doors. What am I missing???
Old Dec 6, 2025 | 02:07 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
When you open the door, does the running board deploy? The running board mechanism has about a 6-8 year life span depending where you live.
Old Dec 13, 2025 | 10:16 AM
Mortipheus's Avatar
Mortipheus
3rd Gear
Yes, the light comes on and the running boards deploy and the door unlocks when you put your hand on the handle, just like it's supposed to. But I'm concerned that it may be the battery, doesn't have enough amps. It's showing 12.4 amps, but is that enough to make the system not want to shut down some of the peripheral electrical uses. You
Old Dec 14, 2025 | 10:02 AM
Mortipheus's Avatar
Mortipheus
3rd Gear
12.4 volts isn't good enough
So, it looks like the battery was putting out 12.4 volts, but when it's not putting out 12.6 volts, the computer decides to shut down some of the peripheral stuff. So, it was a sign that the battery was starting to have issues since it was at the end of its life. So, I put a brand new one in it and drove it over 10 miles and all of a sudden everything's working fine. So, that's what it was.
Old Dec 16, 2025 | 04:53 PM
meborder's Avatar
meborder
I’d recommend resetting the battery life in the BMS with the new battery. They are supposed to be able to update the battery status on their own, but I’ve had problems with it updating.
if you have a scan tool, I’d just recommend going in and setting the battery life to “new” or “100%”
helifixer
Arizona Chapter
Mar 12, 2010 06:27 PM
ScottsWife
34
Apr 18, 2008 05:09 PM
3broncocrazy
Georgia Chapter
Aug 7, 2007 06:01 AM
Fomoko1
Apr 10, 2006 08:42 AM
wolverine289
Montana Chapter
Jan 14, 2005 02:27 PM
