2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Missing on one cylinder
Old Nov 1, 2025 | 07:05 PM
Mefordz's Avatar
Mefordz
1st Gear
11 expedition, 5.4, missing on cyl 3, replaced coil, plug, injector, 125 lbs compression.
Bought it site unseen from wrecker serv., 257,000 miles.
Been rode hard, put up wet.been messing with it for 2 weeks now,swapped coils, swapped injectors, plug looked good, but replaced it anyway.
Wiring seems good,coil fires, injector seems to work right.
I'm not good with fuel infection, prefer carbs anyway.
Have I missed any steps?
I don't own a real scanner, just little code readers.
Don't know anyone that owns one either.
Old Nov 2, 2025 | 06:49 PM
Beechkid's Avatar
Beechkid
Doa leakdown test on that cylinder.... you will know for sure then.....
Old Nov 6, 2025 | 11:44 AM
meborder's Avatar
meborder
I’d be willing to bet it spit out a cam follower.
If you can wedge open the CMCV in the intake, it might run on all 8.
#3 and #7 are the two most common cylinders to loose a follower.
Old Nov 6, 2025 | 03:07 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Don’t let that curve you. Fuel, spark and compression need to be on the up and up for an engine to run right.
​​​​​​​Figure that out before firing the Random Parts Cannon at this.
mojobaby
Jul 27, 2021 11:57 AM
6Fords
Jan 22, 2014 06:32 PM
erpshouse
2004 - 2008 F150
Jan 18, 2011 06:47 PM
cowboy49
1997 - 2003 F150
Jan 6, 2007 05:35 PM
strokin72
Feb 28, 2006 04:41 PM
