P0232 runs but not good
Old Aug 14, 2025 | 04:52 PM
Erock631's Avatar
Erock631
01 f350 7.3
code P0232 and it says fuel pump circuit high voltage
The wait to start light doesnt come on the dashboard and dont hear the usually click at key turn which seemed to sound like a relay click or electrical click
Truck was running and slowly start to mis from multiple cylinders
Will start up and misfire bad but second you press on gas pedal it will die almost instantly
fuel pump was replaced last year maybe has 1k miles on it but it was the only cheap Chinese brand autozone had at the time
fuel tank and filter recently replaced
Move relays and fuses around just incase including the one behind radio
new ford icp and cps from riffraff 2 months ago
Old Aug 14, 2025 | 09:07 PM
Pikachu's Avatar
Pikachu
That code means voltage was detected on the fuel pump monitor circuit while the fuel pump was not commanded on. Read through pinpoint test FK11
1997fordf350
May 18, 2013 10:54 AM
jgrasty7
1983 - 2012 Ranger & B-Series
Nov 20, 2009 02:55 PM
87f150and90rangersxt
Nov 4, 2009 05:28 AM
Rob Cuenin
General Automotive Discussion
Aug 26, 2008 08:59 AM
yellowmatter
Dec 1, 2006 05:43 PM
