Swap in a 6.0 Intercooler to our 7.3L
Old Aug 3, 2025 | 12:22 AM
John in OkieLand's Avatar
John in OkieLand
Question Swap in a 6.0 Intercooler to our 7.3L
Would this really be beneficial?
Old Aug 3, 2025 | 11:52 AM
bwguardian's Avatar
bwguardian
Looks to be well built and bigger. If I had a later year model 7.3L with the plastic end tanks and was having issues, I'd definitely consider these. Both of our trucks are early model 7.3L's which have the aluminum end tanks, so unless something goes wrong or I decide for much more power...which probably won't happen...then yes I'd look closer at these.
Old Aug 3, 2025 | 09:04 PM
Tpayne621's Avatar
Tpayne621
I scored a 6.0 banks intercooler a while back on marketplace for a steal of deal. Just ain't got around to throwing it in yet. I need to get around to that and see if I notice a difference.
Old Aug 4, 2025 | 02:01 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Need correctly sized boots to fit the 6.0 IC into a 7.3 engine bay. Otherwise plug and play.
Back when I installed the Mishimoto 6.0 I was towing a 5er and I noticed a drop in EGTs in the mountains. I enjoyed that combo for a dozen years until CA smog failed me for it. Swapped in OEM. Since then I have not towed the 5er yet EGTs look pretty much the same around town. Of course the test would be towing the 5er in the mountains but I cannot replicate that atm.
So basically I have no valid test results to confirm but I'd gladly use a 6.0 if I could.
Old Aug 4, 2025 | 02:33 AM
INFRNL's Avatar
INFRNL
No need to upgrade unless something is wrong with your stock cooler.
The unit in the video should be identical to their 6.0 cooler...this means they are charging $200 for 2 boots and clamps
Old Aug 4, 2025 | 08:43 AM
FordTruckNoob's Avatar
FordTruckNoob
Want to maximize your charge air cooling? Get this.
https://www.gohypermax.com/ProductDi...a-9bcaa7ef9030
Old Aug 4, 2025 | 08:52 AM
John in OkieLand
IF the stock Intercooler is good up to 300 hp,
just about 99% of us on this forum, will never need that.
and this ensures that I will never buy one
Retail Price: $4,000.00
Our Price: $3,250.00
Old Aug 4, 2025 | 08:59 AM
FordTruckNoob
I figured you would "enjoy" that part.
Old Aug 4, 2025 | 06:57 PM
RigCity's Avatar
RigCity
Have seen reports it reduces egts but not a priority upgrade for a mostly stock truck.
Old Aug 6, 2025 | 02:12 AM
aawlberninf350
It's a Van Gogh
Best part of that design is it uses the available volume the 6.0 IC uses, yet uses OEM boots.
If you can look past the cost it's great.
Old Aug 6, 2025 | 08:39 AM
FordTruckNoob
I can tell you it uses up all the available space where the intercooler goes in the front subframe.
Old Aug 6, 2025 | 10:00 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
When Hypermax introduced the Tapercore in 1999 / 2000, the price was $800.
Then the retail price jumped to $1,200 after 9/11, but the "sale" price was still in the $900 range.
Then for a long time the retail price was $1,600, on sale for $1,200.
Then the retail price broke the $2,000 range, while the sale price was still around $1,600 or more, but not less.
Fast forward to today... $4,000? Wow. I should have bought a bunch of those things 25 years ago, which would have done better than a couple of my stock picks.
Old Aug 7, 2025 | 12:46 PM
RA101725's Avatar
RA101725
Banned
Gold per oz could be had for ~$300 for a brief spell back around that same pre-9/11 time period. Unbelievable. The million dollar question of course is whether the gold or intercooler is really THAT much more valuable today, or the currency by which its price is measured by is just that much more worthless. In reality probably some of both.
Old Sep 13, 2025 | 08:36 AM
WNYPSDguy's Avatar
WNYPSDguy
I put a 6.0 intercooler in mine a couple years ago since it was a 10 minute job at the local junkyard to extract. Supposed to be plug and play except for the boots, but I had huge interference with tranny cooler. No way it was going in as is. I was swapping to the big Mishimoto cooler the next week so I just used tyraps on the old cooler to support it but bringing it up as a potential concern. I do not know if my trans cooler was stock or aftermarket….
Old Sep 13, 2025 | 02:57 PM
John in OkieLand
I removed the OEM ATF cooler so it was not an issue,
the 6.0 cooler slipped right in
Nostalgiaguru
General Diesel Discussion
Dec 27, 2023 08:51 PM
loatch
Engine Swaps
May 15, 2022 05:23 PM
damicofuel
Jan 17, 2010 03:03 PM
