Hi all, I am traveling through the CO Springs area this week. 2013 F-350 went into a death wobble on the interstate while towing the RV. I wanted to post here and see if anyone in the area knew of a reputable shop with experience diagnosing this problem.
This isn't the first time we've had this problem. Bought the truck in 2023, had it then. Replaced ball joints, tie rod ends, track bar, steering damper, shocks, then had it aligned. Problem went away for a year. Next time it happened, I put in caster bushings and had it aligned. Now a year later, hit a bump on the interstate and got the death wobble again.
At this point, I am tired of the issue and don't have a place to work on it myself while traveling. Any advice on a shop that does good suspension work and doesn't break the bank would be greatly appreciated!
