2019 - 2023 Ranger Everything about the new 2019-2023 Ford Ranger.
2019 Ranger factory receiver hitch location
Old Jan 18, 2025 | 07:48 AM
UP_There's Avatar
UP_There
I just recently bought a 2019 Ranger Lariat. The aftermarket bumper was bent, so I ordered a replacement. My issue is, the factory receiver hitch on mine, is located exactly where the license plate is. The prior owner had a license plate frame that was on a hinge mounted to the top, so it could flip up when the hitch is installed. I have searched and searched, and I'm thinking that my receiver is higher than almost ALL other Rangers possibly? If I don't modify the receiver, or even completely replace it with an aftermarket, my receiver is going to stick straight out of the license plate by a couple inches. Not exactly optimal!
Where and what height are your factory receiver hitches on your Rangers? Thank you
Old Jan 18, 2025 | 11:29 PM
swann79's Avatar
swann79
Runs directly under the bumper on my 2020, factory hitch and bumper. I can get pics and measurements tomorrow, if they will help.
Old Jan 19, 2025 | 06:42 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by UP_There
I just recently bought a 2019 Ranger Lariat. The aftermarket bumper was bent, so I ordered a replacement. My issue is, the factory receiver hitch on mine, is located exactly where the license plate is …
Pic ??
sounds like you need to go back to a OEM Stock rear bumper.
Old Jan 19, 2025 | 07:30 AM
UP_There's Avatar
UP_There
Originally Posted by BROWN DOG KTM
Pic ??
Heres a pic with it removed.  You can see how high up my receiver is.  I am thinking mine is too high to work with ANY bumper pretty much!  The aftermarket one that came on this, my plate covered it, and was mounted on a spring hitch.  My plan is to remove the hitch, and install a different one.
Here's a pic with it removed. You can see how high up my receiver is. I am thinking mine is too high to work with ANY bumper pretty much! The aftermarket one that came on this, my plate covered it, and was mounted on a spring hinge. My plan is to remove the hitch, and install a different one.
Old Jan 19, 2025 | 07:34 AM
UP_There's Avatar
UP_There
Pic ??
Not much left on her that is factory lol
Old Jan 23, 2025 | 01:02 PM
UP_There's Avatar
UP_There
This is not my truck, this is on a Maverick. But this is the same location that my receiver hitch is!   Im thinking mine is NOT factory.   I'm removing it completely,  because its not going to work with any bumper I choose
Old Jan 23, 2025 | 02:36 PM
BROWN DOG KTM
That lil maverick is most likely a uni-body with no frame I’d bet.
Ranger has a frame & “should” have a 2” receiver hitch coming out under the rear bumper like all pickup trucks.
I’ve never seen one like you describe.
Old Jan 23, 2025 | 04:55 PM
UP_There's Avatar
UP_There
The picture above of my Ranger is basically the same as the Maverick location of the hitch. It's sorta tough to tell with the bumper off, but the receiver is at the height of the lower part of the license plate. Really a dumb spot to have it!
BROWN DOG KTM
All Things Towing
May 17, 2022 01:36 PM
Roy Barrow
May 21, 2021 07:42 AM
amyandscott
2015 - 2020 F150
Jun 14, 2015 09:37 PM
X_archie
Crossovers
May 12, 2009 12:18 PM
