Second motorcraft coolant bottle cap that doesn't fit...
Old Jun 9, 2024 | 08:25 PM
Lex2002's Avatar
Lex2002
I keep losing coolant and I suspected the bottle cap. The coolant dye accumulates under the cap.
I ordered a second one and look at this..
Old Jun 9, 2024 | 08:37 PM
kenn_chan's Avatar
kenn_chan
That's rather concerning, Where did you order from? are the "threads" in good shape on the bottle?
Old Jun 9, 2024 | 08:57 PM
Lex2002's Avatar
Lex2002
Ya the threads look fine on the bottle.
Last cap fit better but it was also leaking. Both motorcraft.
Old Jun 9, 2024 | 09:05 PM
Lex2002's Avatar
Lex2002
Just checked and the cap in the video is a Ford part from Scamazon.
Old Jun 9, 2024 | 10:15 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
https://www.riffraffdiesel.com/degas...nt-bottle-cap/
Stop getting parts of cramazon folks. Fleabay is worse.
Old Jun 9, 2024 | 10:40 PM
John in OkieLand's Avatar
John in OkieLand
when I bought my '02 Excursion 2 years ago, the "Motorcraft" cap on it fit like that.
went to Advance Auto and had them order me a genuine Motorcraft cap, the 1st one was junk, sent it back, the 2nd one fits and clicks like it should
Old Jun 9, 2024 | 10:54 PM
Kwikkordead's Avatar
Kwikkordead
I'm on the other side of the street. Two motorcraft tanks with caps that came straight from the Ford dealer and they couldn't tighten up because the click part was weak. Bought an aftermarket tank and the cap was much stronger in the click part of the assembly.
Old Jun 10, 2024 | 02:12 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
My recollection is match the parts: OEM tank and cap or aftermarket tank and cap. Don't mix.
Old Jun 10, 2024 | 09:25 AM
Lex2002's Avatar
Lex2002
If only I could remember where I bought the last expansion tank from...
Old Jun 23, 2024 | 02:10 PM
Lex2002's Avatar
Lex2002
I bought a new motorcraft cap from Amazon. Fits better. I guess my coolant bottle is motorcraft and not Ford?
This one doesn't pull off but I'm still losing coolant... Even though water pump and all hoses were changed recently. Need to pressurize system.
Old Jun 23, 2024 | 02:19 PM
John in OkieLand
My radiator cap was like that, it would click but was still loose.
I ordered up a new Motorcraft Cap from a local auto parts store, it fits tight like it should
Old Jun 25, 2024 | 07:44 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Correct, dorman/generic china cap & tank threads different that original oem & thus not interchangeable. With pretty much everything being made over there (incl motorcraft) you've got to be careful
Old Jun 25, 2024 | 08:11 AM
RA101725's Avatar
RA101725
Banned
Dorman bottle I put in about a month ago works fine with the OEM cap. In fact it looks and feels no different than the OEM replacement bottle that lasted 100k miles.
Sounds like the bottle might be the problem either way. That looks like it might be one of the old style Dorman bottles that didn’t fit right with the OEM cap, so I’d chuck it just because of that alone. Those pinch clamps on the little sucker hose need to go too. The one on the rad end was actually causing a cold leak.
Old Jun 25, 2024 | 11:06 AM
Lex2002's Avatar
Lex2002
Hard pass on Dorman when motorcraft available.
Old Jun 25, 2024 | 10:36 PM
Kwikkordead
Dorman probably contract manufactures for Motorcraft.
