Hey fellas I recently got a 2006 Ford f-250 5.4 from my cousin he told me it starts but won't stay running so I had a buddy put his diagnostic tool on there and it popped up 2 codes. The first one was camshaft sensor bank2. That's the driver's side correct right under the intake? The second one was fuel rail pressure sensor. Now I'm no mechanic but common sense tells me it's going to be the only sensor on the fuel rail correct?
A code relating to a sensor does not mean the sensor itself is bad, it just means that monitored circuit detects a fault. It could be a bad sensor but that's only going to be proven out by running diagnostics, not throwing parts at it.
Post the codes and some one will chime in with possible causes.
a bad fuel pump power module may not throw a code. The motor has running problems?
It's most likely a badly corroded Fuel pump power module above the spare tire,
that has huge amounts of corrosion on it's aluminum base. There is a kit that
has rubber spacers that install a new module approx. 5" long off of the frame a bit.
If you see tons of white crap at the base of the module its a bad puppy.
