Sponsored by: Real Truck
Jump seat removal
Old May 18, 2024 | 08:08 AM
carlsson's Avatar
carlsson
Jump seat removal
How is the center front jump seat attached in the front on 2011 to 2016 superduties? I have removed the nuts at rear, but cannot see any fasteners at front. Im hopefull the srs (airbag) module is underneath? Mine is 2016 f350 xl with rubber floor mat.
Old May 18, 2024 | 01:20 PM
masonlift's Avatar
masonlift
If I recall you need to remove both seats to remove jump seat as its front legs are under the inner legs of outer seats
Old May 19, 2024 | 09:31 AM
carlsson's Avatar
carlsson
After more searching, I have found you have to remove the jump seat cushion with the t50 bolts at rear, then you can access the two nuts that hold front bracket down. You do not have to remove the drivers seat.
erich545
Dec 28, 2016 12:14 PM
SaltySenior
May 2, 2015 07:54 PM
porthole
6.7L Power Stroke Diesel
Jan 1, 2011 05:29 PM
timmyjimmy5150
1997 - 2003 F150
Feb 15, 2006 06:26 PM
04SCREW
2004 - 2008 F150
Jun 13, 2004 11:13 AM
