I have the exact same issue. I have the front of the 2020 F550 6.7 torn apart but I don't know if I wired the fan clutch correctly.
I have this diagram but not the end that goes into the clutch. I've seen two different diagrams. So I don't want to put it back together until I'm sure I've got it right. I also have two pigtails that plug into the clutch but they are wired different. One pin 2 is blank and the other pin 3 is blank.
These are the voltages I have at each pin with ignition on:
3.51
5.04
11.41
12.06
So I just need to know where they go on the clutch?
Any help will be most appreciated!
This is my RV and I'm stuck until I can get this resolved.
