Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2006 Escape Hybrid transmission shudder/stutter
Old Dec 31, 2023 | 09:53 AM
WHanson's Avatar
WHanson
2006 escape hybrid, 2.5L 4 cyl, 150k miles
in winter at below 32F, the transmission has an occasional stutter (or shudder)when shifting at around 3000 rpm at around 45-50 mph.I took it to the transmission shop and they found the transmission fluid low and added some to bring it up to level. This reduced the frequency of occurrence, but didn’t completely eliminate it.
It occasionally happens at normal temperature if one aggressive drives with foot on the accelerator on a on-ramp while accelerating to traffic speed but is mostly avoided by driving conservatively but is readily observed at -10F even when the vehicle would seem to be warmed up after driving 20 miles or so…
Wondering if any others has experienced this?
Considering a transmission fluid change is needed due to age of fluid and miles on the vehicle.
Also wondering if there might be pressure diaphragms, plates, or something needed to be changed? I’m not so familiar with this transmission and the gear shift controls, but stutter behavior is much like a prior owned dodge caravan’s transmission coil solenoid pack failure.
Old Dec 31, 2023 | 04:35 PM
bmuhlbach's Avatar
bmuhlbach
my 01 had like a shutter when going a constant speed. it was a coil pack on its way out. it had a pending code stored. also on the cd4e. alot of people do a drain and refill. 2 times in a row to replace the old fluid. i think it takes 4 quarts do do a exchange
Old Jan 16, 2024 | 10:26 PM
WHanson's Avatar
WHanson
The weather turned quite cold… around-10F. I experience the shift problems at each shift point after having allowed the escape to warm up on the driveway around 20 minutes.
I found the following YouTube video suggesting to me that the cold winter temperatures might be causing the transmission adaptation table to require retraining. I did not know that Ford has implemented adaptive shifting technology into their transmissions beginning in 2006.
Old Feb 15, 2024 | 05:36 PM
bmuhlbach's Avatar
bmuhlbach
was watching you tube and A Ford trans tech said to add this after a fluid change lube gard instant shutter fix. a little red tube. about 12.00 at Advanced auto parts. On my 2017 it shuddered around 25 mph. i drained and refilled it was better but still had a little shudder. I added the lube gard and its great now.
Old Feb 15, 2024 | 08:27 PM
WHanson's Avatar
WHanson
bmuhlbach, Thank you!
I see the description of the Lubegard product online and will give it a try.
The change of the transmission fluid by itself resulted in the same behavior as before. But it was good to have the fluid change done so then I can try out this product knowing that I am starting with clean transmission fluid.
LiquidSpecialties
2004 - 2008 F150
Dec 21, 2014 06:54 AM
wvmailman
2004 - 2008 F150
Apr 2, 2011 08:49 PM
shailey
Modular V8 (4.6L, 5.4L)
Oct 28, 2009 03:11 PM
ImSoAmish
Nov 25, 2008 01:20 PM
