2023 seat belt chime cancel process
Old Oct 4, 2023 | 07:34 PM
uncle kaw's Avatar
uncle kaw
4th Gear
TIA!! ok guys....has anyone been successful in doing the process, that's in the owners manual, to cancel the seat belt reminder chime? I've tried it numerous times with zero success. thx again, and yes I'm religious about using my seat belt when I'm on the road
Old Oct 4, 2023 | 07:36 PM
S1njin's Avatar
S1njin
I don’t mind the chime but God I HATE the seat belt graphic that shows up on the cluster screen in the cowl every time I start the truck. Ever time I dismiss it I have to click around to get back to the view I like.
Old Oct 4, 2023 | 07:43 PM
OX2's Avatar
OX2
FORSCAN is your friend, completely deleted it on mine.
Old Oct 4, 2023 | 08:12 PM
uncle kaw's Avatar
uncle kaw
4th Gear
I tried with a snap on Solas scan tool...nada. You think a dealer would do it? may have to sign a waiver
Old Oct 5, 2023 | 07:48 AM
S1njin's Avatar
S1njin
Ugh. I'm trying very hard not to screw around with anything under the covers.
Old Oct 5, 2023 | 09:25 AM
GreyShadow350's Avatar
GreyShadow350
You were able to delete the seatbelt graphic using FORSCAN? This is the first I've seen this.
Old Oct 5, 2023 | 10:13 AM
Devil's Advocate's Avatar
Devil's Advocate
Here the manual process if you don't forscan.
Put parking brake on (make sure all doors are closed)
turn ignition on, but don't start your truck
Wait until your AIRBAG light (on a cluster) goes out
(within 30 seconds) buckle up and unbundle 3 times, buckle and unbuckle 4th time to confirm
DA
Old Oct 5, 2023 | 01:44 PM
kry226's Avatar
kry226
Yup, check the FORScan thread.
Old Oct 5, 2023 | 03:59 PM
OX2's Avatar
OX2
Yes, see post 2261 in FORSCAN thread. I also have a post at 2301, clarifying (in general), the "checksum" column
Old Oct 6, 2023 | 02:12 AM
Sport45's Avatar
Sport45
Cant help with the original question, but this should link directly to the post referenced above…
Post 2261
Old Oct 6, 2023 | 06:26 AM
GreyShadow350
Originally Posted by Sport45
Cant help with the original question, but this should link directly to the post referenced above… I don’t know if it will
Post 2261
Thanks everyone. After 'kry226', posted yesterday, I went searching for the FORSCAN thread and found those posts. I ordered my OBDLink EX yesterday, and have to start trying to figure out how to use FORSCAN. Been reading about it off and on, but get overwhelmed trying to follow what to do. I'm going to have to spend some serious time this weekend, trying to understand how to use it.
Old Oct 6, 2023 | 08:51 AM
CBEllis's Avatar
CBEllis
DA
Yup - I think this is spot on. The owners manual is wrong. And the only other note, you have to do each seat individually. I thought, in my 2017, I did it once, from the driver's seat, and it turned off the chime for all 6 buckles. Not so in this 2023.
Old Oct 6, 2023 | 09:35 AM
S1njin's Avatar
S1njin
Is it just the chime or does it also kill the annoying center cluster notification?
Old Oct 6, 2023 | 10:06 AM
GreyShadow350
Just the chime.
Old Oct 6, 2023 | 11:59 AM
Devil's Advocate
Just the chime. I went into forscan and did the all seat belt chime remove and now the warning notification is gone too! Worth it.
DA
stubbfarmer
6.7L Power Stroke Diesel
Oct 8, 2011 11:25 PM
gr8scott72
Aug 1, 2011 12:09 PM
Big Sky Rancher
6.4L Power Stroke Diesel
May 1, 2007 08:50 AM
wallace_cody
2004 - 2008 F150
Mar 2, 2005 12:22 PM
scottb1014
2004 - 2008 F150
20
Apr 20, 2004 07:00 PM
