Sponsored by: Real Truck
2016 f350 transmission not shifting correctly
Old Aug 23, 2023 | 10:44 PM
collinsmc560's Avatar
collinsmc560
1st Gear
2016 f350 6 speed transmission shifts normal until warms up ( about 3 miles driving) then in 1st and 2nd won't shift until about 3500rpm is reached. 3rd gear wont shift to 4th, but if I put into manual and back to drive trans will shift normally, (lower rpm's) into 4th, 5th and 6th gear. Also if I place into manual and use up and downshift button will shift just fine. Any ideas??
Old Aug 24, 2023 | 01:19 AM
85e150's Avatar
85e150
Get the codes read.
Old Aug 24, 2023 | 06:08 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I would presume if it's shifting that harshly it has some kind of engine code, even if the light isn't on there should be a stored code.
I would get codes read, check trans fluid level/condition, and go from there.
mzuern
Jun 6, 2022 12:32 PM
DerekF350disel
6.7L Power Stroke Diesel
17
Apr 18, 2016 09:01 PM
Blue94Bronco
1978 - 1996 Big Bronco
Nov 13, 2012 07:14 AM
Meat_fire
Feb 2, 2008 06:02 PM
