1993 5.0 , auto trans, dual tanks. f150 bucks and stalls out , I have been scratching my head on this for so long. Truck starts up, idles great , but after driving for a few minutes check engine light comes on and will stutter, if you let off , or throttle all the way it will stop, it will go about three miles before it bucks and shakes , then will stall out and die. Won't restart and cranks over kinda slow. If you let it sit it will start right back up.
I know not the throw parts at it , but ive replaced the tps , coolant temp sensor , icm, fuel filter and coil and distributor.
sorry for the long post boys but i just cant figure this out.
These problems are usually pretty simple to solve with a multimeter and a paperclip. First thing to do is to pull the trouble codes.
YOu can use this procedure. https://www.ford-trucks.com/forums/1...aper-clip.html
Let us know what you find and we can steer you in the right direction.
Ran the koeo codes and the koer codes ,
koeo codes are : 23, 31,85. Memory codes are 22,41,63,31,33
Koer codes are 21, 23,41,31,13,77.
Thats not correct. You should have 3 digit codes. Maybe its 233 and 185. 224, 163, 313(X)
Try retrieving codes again, but this time expect a 3 digit code.
